jmos4 Posted March 29, 2017 Share Posted March 29, 2017 Hi all, I have a vendor drawing that shows nothing in model space, in paper space is geometry and title blocks, but the part geometry is not selectable, yet if I do a DDInsert I can insert each part geometry view, so I am totally perplexed on what I need to do to simply copy the files out into model space. I have QSelected the viewports and nothing is frozen in the file. I normally don't work in paper space so this is new to me and really haven't seen this before. Regards, Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 29, 2017 Share Posted March 29, 2017 Could you attach a copy of the drawing (.dwg file) to your next post so we can have a go at it ourselves? Quote Link to comment Share on other sites More sharing options...
jmos4 Posted March 29, 2017 Author Share Posted March 29, 2017 Hi, I wish I could, but its proprietary, but its the weirdest thing, the drawing/paper space has all the parts in it, just nothing in model space, when you list the drawing it gives you so many items that are not in current space and 1 object was the paper space viewport, not sure if that helps but this is what its telling me. Regards, Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 29, 2017 Share Posted March 29, 2017 Listen, we need just enough of the drawing that we can visualize the problem. Delete the "top secret" stuff and save under a new name then attach to a post. One drawing is worth about one thousand words right about now and I bet neither of us are that verbose. LOL Quote Link to comment Share on other sites More sharing options...
jmos4 Posted March 29, 2017 Author Share Posted March 29, 2017 Hi again, I would but that is the issue, I can't select it let alone delete items. attached is a image of drawing, the blueish items are the ones I can select and explode the part image is just that a image, yet if I insert a block I can get that piece or sheet image. Regards, Quote Link to comment Share on other sites More sharing options...
maratovich Posted March 29, 2017 Share Posted March 29, 2017 Model space -> View -> Zoom all Quote Link to comment Share on other sites More sharing options...
jmos4 Posted March 29, 2017 Author Share Posted March 29, 2017 Hi again, Yes that was the first thing I tried, along with making sure all the layers were thawed and on. Best I can figure the blocks are in viewports in paper space and I have no idea on how to extract the geometry from them as I can not select them. Regards, Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 29, 2017 Share Posted March 29, 2017 The geometry may very well be inserted (attached cross references) images or even pdf documents. Select window EVERYTHING on a layout tab, open PROPerties and check the list of items selected for xref's, or groups, blocks, and other troublemakers. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 29, 2017 Share Posted March 29, 2017 Activate a viewport and try to select the objects or go to model space and press Ctrl+A to select everything in model space. Quote Link to comment Share on other sites More sharing options...
