Updating attributes with vba form
blintz
Hello
with vba / autocad I make a form for extract, from block, the attributes. This block contains 37 different attributes. A combobox reads the blocks present in model space, select the block in textbox read value attribute
e.g.
attrib. "1Tag" = "01" value
attrib. "2Tag" = "02" value
etc ..
I want to insert new value of attribute in the block
e.g
old
TextBox2 / attrib. "1Tag" = "01" value
new
TextBox2 / attrib. "1Tag" = "AA" value
code:
Private Sub ComboBox1_Change()
Dim BlockRef As AcadBlockReference
Dim varAttributes As Variant
Dim intAttribCount As Integer
Dim newss As AcadSelectionSet
Dim i, o, x As Integer
' Cancella la Selection Set se esiste
On Error Resume Next
If Not IsNull(ThisDrawing.SelectionSets.Item("ss")) Then
Set newss = ThisDrawing.SelectionSets.Item("ss")
newss.Delete
End If
ListBox1.Clear
TextBox32.Value = 0
TextBox1.Value = ComboBox1.Value
Set newss = ThisDrawing.SelectionSets.Add("ss")
newss.Select acSelectionSetAll
If newss.Count > 0 Then
i = 1
o = 0
For x = 0 To newss.Count - 1
newss.Item (o)
If newss.Item(o).ObjectName = "AcDbBlockReference" Then
If newss.Item(o).EffectiveName = TextBox1.Value Then
i = i + 1
varAttributes = newss.Item(o).GetAttributes
For intAttribCount = LBound(varAttributes) To UBound(varAttributes)
If varAttributes(intAttribCount).TagString = "1REV" Then
TextBox2.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2REV" Then
TextBox3.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "3REV" Then
TextBox4.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "4REV" Then
TextBox5.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1MOD_REV" Then
TextBox6.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2MOD_REV" Then
TextBox7.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "3MOD_REV" Then
TextBox8.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "4MOD_REV" Then
TextBox9.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1DATA_REV" Then
TextBox10.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2DATA_REV" Then
TextBox11.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "3DATA_REV" Then
TextBox12.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "4DATA_REV" Then
TextBox13.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1FIRMA_REV" Then
TextBox14.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2FIRMA_REV" Then
TextBox15.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "3FIRMA_REV" Then
TextBox16.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "4FIRMA_REV" Then
TextBox17.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "DATA_CREAZIONE" Then
TextBox18.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "DISEGNATORE" Then
TextBox19.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "VISTO" Then
TextBox20.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "APPROVATO" Then
TextBox21.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "LINK" Then
TextBox22.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1CLIENTE" Then
TextBox23.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2CLIENTE" Then
TextBox24.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "MOD_MACCHINA" Then
TextBox26.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1MATR" Then
TextBox27.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2MATR" Then
TextBox28.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "#N-1" Then
TextBox29.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "#N" Then
TextBox30.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "#N+1" Then
TextBox31.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "1SE_POT" Then
TextBox33.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "2SE_AUX" Then
TextBox34.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "3SE_PLCIN" Then
TextBox35.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "4SE_PLCOUT" Then
TextBox36.Value = varAttributes(intAttribCount).TextString
ElseIf varAttributes(intAttribCount).TagString = "5SE_PLCLAYOUT" Then
TextBox37.Value = varAttributes(intAttribCount).TextString
'"ETC. ETC."
End If
If TextBox33.Value = "" Then
Else
TextBox25.Value = TextBox33.Value
End If
If TextBox34.Value = "" Then
Else
TextBox25.Value = TextBox34.Value
End If
If TextBox35.Value = "" Then
Else
TextBox25.Value = TextBox35.Value
End If
If TextBox36.Value = "" Then
Else
TextBox25.Value = TextBox36.Value
End If
If TextBox37.Value = "" Then
Else
TextBox25.Value = TextBox37.Value
End If
Next intAttribCount
ListBox1.AddItem (o)
o = o + 1
ElseIf newss.Item(o).EffectiveName <> TextBox1.Value Then
o = o + 1
End If
ElseIf newss.Item(o).ObjectName <> "AcDbBlockReference" Then
o = o + 1
End If
Next x
End If
TextBox32.Value = i - 1
End Sub
With the "EXIT" button close the form but strangely vba editor does not end the macro
code
Private Sub CommandButton3_Click()
Unload Me
Set UserForm1 = Nothing
End Sub
I hope for your help
regards
