How to apply CHPROP command on selected items
Hi all,
I have following lisp which selects all the texts containing "xxx":
(defun foo (text)
 (sssetfirst
   nil
   (ssget "_x"
          (list '(-4 . "<OR")
                '(-4 . "<AND")
                '(0 . "*TEXT")
                (cons 1(setq text(strcat "*" (strcase text) "*,*" (strcase text T) "*")))
                '(-4 . "AND>")
                '(-4 . "<AND")
                '(0 . "MULTILEADER")
                (cons 304 text)
                '(-4 . "AND>")
                '(-4 . "OR>")
(foo "xxx")
What I need to do is to change selected items colour. I was hoping someting like:
(command ".CHPROP" "Color" "5" "" "")
to do the job but obviously that is not the case.
Your almost there just need to assign a variable (tss) to the selection set and combine the two.
(defun foo (text)
 (sssetfirst
   nil
   (setq tss
   (ssget "_x"
          (list '(-4 . "<OR")
                '(-4 . "<AND")
                '(0 . "*TEXT")
                '(-4 . "AND>")
                '(-4 . "<AND")
                (cons 304 text)
                '(-4 . "AND>")
                '(-4 . "OR>")
(command "CHPROP" tss "" "Color" "5" "" "")
Edited by SunnyTurtle
prentices missing
(defun foo (text)
 (sssetfirst
   nil
   (setq tss
   (ssget "_x"
          (list '(-4 . "<OR")
                '(-4 . "<AND")
                '(0 . "*TEXT")
                '(-4 . "AND>")
                '(-4 . "<AND")
                (cons 304 text)
                '(-4 . "AND>")
                '(-4 . "OR>")
:unsure:
Command: (foo "xxx")
; error: too many arguments
@SunnyTurtle, Always try to void global variables unless you are in need of this process. :)
Although I prefer using the iteration through each entity but here I am following your way for your learning or so.
(defun foo (text / ss)
 (sssetfirst
   nil
   (setq ss (ssget "_x"
          (list '(-4 . "<OR")
                '(-4 . "<AND")
                '(0 . "*TEXT")
                (cons 1 (setq text(strcat "*" (strcase text) "*,*" (strcase text T) "*")))
                '(-4 . "AND>")
                '(-4 . "<AND")
                (cons 304 text)
                '(-4 . "AND>")
                '(-4 . "OR>")
 ss
(if (setq ss (foo "xxx"))
 (command ".CHPROP"  ss "" "Color" "5" "")
Thanks Tharwat. Code is working now.
Is it an easy fix if I want the code search through Attributes as well?! After running the code above, I realised some of the "xxx" strings are attributes (unfortunately)
You're welcome anytime.
Attribute Definitions or Attributes in blocks?
Thank Tharwat you are right. I make that mistake too often and should be trying to improve that.
Attributes in blocks. I need to hightlight them in RED (true color) in order to stand out in hardcopy prints.
Should iterate through each Attribute in blocks to be able to change Color, String, Text Height .... etc.
