dlle Posted April 14, 2017 Share Posted April 14, 2017 New to the forums so excuse me if this isn't the right place to post... I was wondering if anyone has encountered the issue of switching between drawings in civil3d 2017 and then trying to type in commands and the current drawing on screen doesn't register the commands. Instead, one of the other drawings open will have the commands partially typed out. It's very random and a pain to recover from because you don't know when it happens or when it ends. If anyone has encountered this, do you know why it happens or how to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted April 14, 2017 Share Posted April 14, 2017 This was a known issue in Civil 3D 2013 (and maybe later versions...?), and the "fix" (before the SP) was to disable LevelOfDetail. More info: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Civil-3D-2015-command-line-stops-working.html Quote Link to comment Share on other sites More sharing options...
dlle Posted April 14, 2017 Author Share Posted April 14, 2017 Thanks for the tip. I'll give it a shot and see if this helps. Quote Link to comment Share on other sites More sharing options...
