Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    sathalex's Computer Details
    Windows
    Asus
    AutoCAD 2015
    Jul 2016
    Russia
    18
    Default Find the highest and lowest mark from the selected "points"
    Hello!
    In my drawing there are 200 primitives "point", how would I quickly find the highest and the lowest of them?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,246
    Hi,
    Easily you can do that by retrieving the coordinates of each point then sort them with their Maximum Y coordinate, then finally the first and the last items in the list would be the Highest & Lowest.
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    If the points have been compiled as a list then
    Code:
    (apply 'max (mapcar 'caddr pt_list))
    (apply 'min (mapcar 'caddr pt_list))
    There are several other metheods available as well. -David
    R12 (Dos) - A2K
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    Sorting should be avoided when trying to determine the extrema of a point set, as the set need only be processed once. This may therefore be performed with O(n) efficiency, whereas sorting is generally on the order of O(n log n).
    I would therefore suggest something like:
    Code:
    (defun maxmin ( lst / mni mxa zco zmi zmx )
        (setq mni (car lst) zmi (caddr mni) mxa mni zmx zmi)
        (foreach  itm (cdr lst)
            (setq zco (caddr itm))
            (cond
                (   (< zmx zco)
                    (setq mxa itm zmx zco)
                (   (< zco zmi)
                    (setq mni itm zmi zco)
        (list mni mxa)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Junior Member
    Windows
    Asus
    AutoCAD 2015
    Jul 2016
    Russia
    18
    Quote Originally Posted by Lee Mac View Post
    Code:
            (cond
                (   (< zmx zco)
                (   (< zco zmi)
        (list mni mxa)
    At the command prompt Error: too few arguments (((
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Worked for me
    Code:
    (SETQ LST (LIST (LIST 10 20 30)(LIST 20 20 20)(LIST 10 10 100)))
    (maxmin lst)
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    Quote Originally Posted by sathalex View Post
    The function is for use in other programs, it does not define an AutoCAD command.
  8. #8
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Awesome (effective) function Lee,
    Just figured out:
    Why don't write something more global using the same algorithm, like accepting function and list arguments (just like vl-sort), i.e.:
    Code:
    (foo (lambda (r x) (< r x)) '(3 8 9 1 5 6 2 7) )
    -> 1
    where lambda is a test function and takes two arguments for comparing:
    r - item to be returned
    x - comparsion item
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    Thanks Grrr - as for a generic function, consider the following:
    Code:
    (defun extremum ( cmp lst / rtn )
        (setq rtn (car lst))
            (if (apply cmp (list itm rtn)) (setq rtn itm))
        rtn
    Code:
    _$ (extremum '< '(3 8 9 1 5 6 2 7))
    1
    Code:
    _$ (extremum '(lambda ( a b ) (< (caddr a) (caddr b))) '((1.2 5.7 8.3) (9.4 2.6 0.3) (5.7 6.6 7.2)))
    (9.4 2.6 0.3)
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    Or recursively:
    Code:
    (defun extremum ( cmp lst )
        (   (lambda ( foo ) (if (cdr lst) (foo (car lst) (extremum cmp (cdr lst))) (car lst)))
            (lambda ( a b ) (if (apply cmp (list a b)) a b))
  1. Want to draw a series of "X" or "l l" lines between 2 points (weld lines)
    By p0peye in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2013, 10:58 pm
  2. Replies: 1
    Last Post: 7th Feb 2013, 10:28 pm
  3. Replies: 10
    Last Post: 29th Jan 2013, 08:38 pm
  4. selected objects not showing up as "dashed"
    By streetmike in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Jun 2010, 08:00 pm
  5. Lisp: Extract highest/lowest value from a list
    By ajs in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2009, 02:58 am
Tags for this Thread
