Is there any way to select by lisp distant objects, without user intervention.
Maybe by the larger coordinates in all 4 quadrants?
Thanks
Welcome to CADTutor w64bit. :)
SELECTALL?
I have "negative" hatches in many DWG files, located far away from the drawing and I want to delete them (not manually).
I don't see how you would be able to do this without any user input.
At the very least I should think you would need to define the extents for all objects which you do not wish to delete.
A simple way is to select all with Ctrl+A. Then press Shift and deselect everything on the screen.
The distant object should remain selected and you can Erase them.
Let's try other approach.
A lisp for selecting all "negative" hatches.
negative = hatches which cannot be seen due to large scale
it can be a lisp for selecting all outside a defined zone.
Are you able to pinpoint this defined zone?
We can try, but if I write it, it would be exact the same approach as I described.
So if my suggestion works, then the lisp would work.
Did you try it?
That is exactly how I would do it too, Stefan. :beer:
What about prompting the user to input a range of hatch scale values to be avoided, so the fault won't be in your code:
_$ (<= 1 2 3)
T
_$ (<= 1 0 3)
nil
_$ (<= 1 4 3)
nil
