andr3flaviano
Hello, guys!
I'm new here. So, please, be gentle.
I had a problem with a routine. I have to open all the drawings in the same folder, compare a specific area of the drawing with a reference and change that area, if necessary. But I have a lot of references to compare, so I need to do that many times.
I've already got a batch to open all the drawings in the same folder. So I just modified it to compare the area with the reference and it worked greatly. The only problem is: When i put that batch inside a loop instruction (to change the reference that will be compared), the batch didn't worked. The following error appears:
; error: bad argument type: streamp nil
Here goes the code. Could someone help me?
(defun c:testloop (/)
(setq c 1)
(while (
(c:opendrawings)
(setq c (1+ c))
); end while
); end function to test the loop
(defun c:opendrawings (/ dwglist dwgname dwgpre file openfile uhoh len)
(vl-load-com)
(if (and (setq dwgpre (getvar 'dwgprefix))
(setq dwglist (vl-sort (vl-remove (strcat dwgpre (getvar 'dwgname))
(mapcar '(lambda (dwgname) (strcat dwgpre dwgname))
(vl-directory-files dwgpre "*.dwg")
(setq uhoh
"Readonly drawings will not be processed!"
(setq len (strlen uhoh))
(progn (setq openfile (open (setq file (strcat dwgpre "myscript.scr")) "w"))
(progn (foreach f dwglist
(if (and
(not (Is_ReadOnly f))
(/= (checkAttFile f) 1)
(write-line (strcat "_.open \"" f "\"") openfile)
(write-line "_.audit _y" openfile)
(write-line "_.qsave _.close" openfile)
(setq uhoh (strcat uhoh "\n" f))
(close openfile)
(command "_.script" file)
(if (= (strlen uhoh) len)
(princ "All drawings successfully processed...")
(alert uhoh)
); end function to open all the drawings
Ok! Sorry.
Hello, guys!
I've already got a batch to open all the drawings. So I modified it to compare the area with the reference and it worked greatly. The only problem is: When i put that batch inside a loop instruction (to change the reference that will be compared), the batch didn't worked. The following error appears:
 (setq c 1)
 (while (<= c 5)
   (c:opendrawings)
   (setq c (1+ c))
   ); end while
 (vl-load-com)
   (setq uhoh
	    (if	(and
                           ; <--- Here I put the routines that I need
	  (close openfile)
	    (alert uhoh)
I do not see anything obviously wrong with the posted code. At what point does the code fail? Is the script created? Posting the code that has been left out may help.
