Cylis0509 Posted May 22, 2017 Posted May 22, 2017 Hi Everyone, Is it possible to temporarily hold a layer state in memory and then restore it? I am working on a drawing cleanup LiSP and part of what it does is bind xrefs and then clean up the layer names (removing XREFNAME$|$) and merging layer names together when they exist in the xref and the current drawing. The issue is that if a layer with the same name was off in the xref but on in the current drawing, it then becomes on when it should be off. (I hope that makes sense) Is there a way to save the state of the xrefs and then restore to the current drawing with out have to write to a file? This will be part of a larger LiSP where I will take the layerstate at the beginning and the last I do is restore the layer state at the end. Thank you Quote
BIGAL Posted May 23, 2017 Posted May 23, 2017 I think you have answered your own question you must write a list of layer states to some where you could do just that make a list which will stay in memory I would do pairs ("layer1" 1 "layer2" 0 "layer3" 3 .. 0 off, 1 0n, 3 frozen etc a pretty simple repeat looking at nth x & nth (1+ x) Quote
Roy_043 Posted May 23, 2017 Posted May 23, 2017 @Cylis0509: You should look at the BINDTYPE variable. Quote
