keiths Posted May 24, 2017 Share Posted May 24, 2017 Help needed, i made a block for a Speed Limit road sign which inserted i can change to various speeds... hope it make sense... Keith Quote Link to comment Share on other sites More sharing options...
steven-g Posted May 24, 2017 Share Posted May 24, 2017 Can you post a copy of the block, it sounds like you could use visibility states in a dynamic block! Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted May 24, 2017 Share Posted May 24, 2017 (edited) Without more information, it's hard to tell what your problem is. Your subject hints that you've tried to include an attribute in your block. Did you create an attribute? What is it doing or not doing? What are its properties? Is the block or the text annotative? The attribute may not appear if the scale doesn't match or if it's too far off. Edited May 25, 2017 by CyberAngel Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 25, 2017 Share Posted May 25, 2017 Steven your right a dynamic block, but why not just make the range of blocks. We have some True Type fonts and they have the advantage of just edit the single character and a new speed pops up. Quote Link to comment Share on other sites More sharing options...
