+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Full Member
    Computer Details
    keiths's Computer Details
    Operating System:
    Win 7
    Computer:
    Dell Laptop E6530
    Discipline
    Construction
    keiths's Discipline Details
    Occupation
    TM Co-ordinator
    Discipline
    Construction
    Using
    AutoCAD 2013
    Join Date
    May 2013
    Location
    Christchurch, NZ
    Posts
    53
    Default Lisp routine to create chevron markings
    Hi,
    Where can i find a lisp routine to create chevrons as used on gores or median islands.
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,877
    Default
    I think CadTools has a chevron feature.
  3. #3
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,702
    Default
    Have a play with this not really finished but.
    Code:
    ; chevron island creater
    ; this use the extrim command to trim shape
    ; By Alan H Jan 2012
    (defun C:Chevron ( / obj pt1 pt2 pt3 pt4 newpt1 newpt2 )
    (acet-error-init (list
                       (list   "cmdecho" 0
                             "highlight" 0
                             "regenmode" 1
                                "osmode" 0
                               "ucsicon" 0
                            "offsetdist" 0
                                "attreq" 0
                              "plinewid" 0
                             "plinetype" 1
                              "gridmode" 0
                               "celtype" "CONTINUOUS"
                             "ucsfollow" 0
                              "limcheck" 0
                       T     ;flag. True means use undo for error clean up.
                       '(if redraw_it (redraw na 4))
                      );list
    );acet-error-init
    (setq obj (car (entsel "\nPick pline or circle")))
    ; should do a object test here
    (setq whatis (cdr (assoc 0 (entget obj))))
    (if (= whatis "LWPOLYLINE")
    (princ "\You have picked something other than a polyline ")
    (princ "\Remake into a pline and do again ")
    (setq dummy (getstring "\press any key"))
    (exit)
    ) ; progn
    ) ; if
    (setq pt1 (Getpoint "\nPick Line start point"))
    (setq pt2 (Getpoint pt1 "\nPick end point"))
    (command "line" pt1 pt2 "")
    (setq gap1 (getreal "\nenter spacing 1"))
    (setq gap2 (getreal "\nenter spacing 2"))
    (setq pt3 (getpoint "\nPick 1st cross point"))
    (setq pt4 (getpoint pt3 "\nPick 2nd cross point"))
    (setq dist (distance pt3 pt4))
    (setq x (fix (/ dist (+ gap1 gap2))))
    (setq newpt1 (strcat (rtos gap1 2 2) ",0.0"))
    (setq newpt2 (strcat (rtos gap2 2 2) ",0.0"))
    (repeat x
    (command "copy" "L" "" "0,0" newpt1)
    (command "copy" "L" "" "0,0" newpt2)
    (load "Extrim")
    (etrim obj pt1)
    (acet-error-restore)
    ) ; end defun
  4. #4
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,702
    Default
    Readable version below, Maunsell is a very large engineering company obviously in Adelaide Australia. Not sure if it was to be released to the public.
    Code:
    ; removed as I dont want to be sued by Maunsell's
  5. #5
    Full Member
    Using
    AutoCAD 2013
    Join Date
    Oct 2014
    Posts
    63
    Default
    Thank you for your reply and changed to Readable version bigal sir.
    But actually​ I don't about Maunsell now I understood.
Similar Threads
  1. Help me create LISP routine to remove duplicates!
    By ktbjx in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Aug 2016, 01:09 pm
  2. Highway design and road markings
    By deanby7 in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th May 2015, 11:14 am
  3. Road Markings
    By MarkCalvert in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jan 2008, 10:35 pm
  4. Road Markings to Scale in Paperspace
    By Primal Scientist in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2007, 09:11 am
  5. Can Anyone Create A LISP Routine For this???
    By raj banerjee in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Sep 2007, 06:26 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
