kippax Posted June 2, 2017 Share Posted June 2, 2017 This is despite its appearance in the drawing. The text is in paper space. Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 2, 2017 Share Posted June 2, 2017 nice ! can you post the file, it would be easier to look at various settings, than trying to guess, if need be strip the drawing down so that only the text remains in a layout and post that (just check it still misbehaves). Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 2, 2017 Share Posted June 2, 2017 Sometimes PDF processors do weird things. If you have a different PDF plotter, try that one instead. CutePDF is still available for free, there are probably others, but I've used that one and can vouch for it. Quote Link to comment Share on other sites More sharing options...
maratovich Posted June 2, 2017 Share Posted June 2, 2017 Your paper is vertical, and in the print settings you have specified a horizontal one. You have auto-rotated text from the direction of paper. Maybe this will help http://wishsoftware.blogspot.ru/2012/02/making-blocks-text-and-hatches-match.html Quote Link to comment Share on other sites More sharing options...
kippax Posted June 6, 2017 Author Share Posted June 6, 2017 Hi ! Sorry for the delay in response. Yes the paper is vertical, but if you look at the print preview it clearly shows that the orientation is portrait with the text aligned accordingly. I have attached the file for anybody that might be in the position to spare me a little time. Many thanks in advance.... LLSA0327 E 63 002 SK05 LINEARLight Flex Detail.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 6, 2017 Share Posted June 6, 2017 I had no problem when I printed your drawing to a PDF file. However, I did change the paper size to read ISO full bleed A3 (297.00 x 420.00 MM). Simple. Quote Link to comment Share on other sites More sharing options...
maratovich Posted June 6, 2017 Share Posted June 6, 2017 Do not you believe us? Why? Here is your file, fixed. LLSA0327 V.dwg LLSA0327 E 63 002 SK05 LINEARLight Flex Detail-A3 V.pdf Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 6, 2017 Share Posted June 6, 2017 Always a good idea to check the paper size dimensions when printing to a rectangular format. Quote Link to comment Share on other sites More sharing options...
kippax Posted June 6, 2017 Author Share Posted June 6, 2017 Cheers people, as you have spotted it's some kind of clash in the "paper orientation". It appears it's not necessarily enough to simply select portrait/landscape. You also have to select the correct orientation in the paper size. All sorted Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 6, 2017 Share Posted June 6, 2017 Yep, those pesky "details" will get you every time. Quote Link to comment Share on other sites More sharing options...
