Is there any lisp to move selected objects to new layer? I found this code (below) works well.. However inside blocks dont chage.
(defun c:nl ( / ss layer)
(and
(princ "\nSelect objects to change to new layer: ")
(setq ss (ssget))
(setq layer (getstring "\nNew layer name: "))
(or
(snvalid layer)
(prompt "\nInvalid layer name.")
(vl-cmdf "_.-layer" "_M" layer "")
(vl-cmdf "_.chprop" ss "" "_La" layer "")
(setvar "clayer" "0")
Hi jyan, welcome to cadtutor.net
I don't know if it exists, but I modified your provided routine to achieve the desired result
(defun c:nl (/ ss layer cnt en)
 (vl-load-com)
 (and
   (setq ss (ssget))
   (or
     (snvalid layer)
;part added by Jef! on june 05 2017
;inspired by Peter Jamtgaard FIXBLKS. Put into lambdas with Cwake's help.
 (setq cnt (sslength ss))
 (while (setq en (ssname ss (setq cnt (1- cnt))))
   (if (= "INSERT" (cdr (assoc 0 (entget en))))
     ((lambda (en / elst bnam flst)
        (setq elst (entget en)
              bnam (cdr (assoc 2 elst))
              flst nil
        ((lambda (func)
           (func bnam)
          (lambda (bnam / benam)
            (if (not (member bnam flst))
                (setq flst  (cons bnam flst)
                      benam (tblobjname "block" bnam)
                (while (setq benam (entnext benam))
                  (if (= (cdr (assoc 0 (entget benam))) "INSERT")
                    (func (cdr (assoc 2 (entget benam))))
                    (vla-put-layer
                      (vlax-ename->vla-object benam)
                      layer
       en
Cheers!
Hi Jef!
That's fantastic. I've been searching for this code for months. You r brilliant. Thank you very much.
Best Regards
Jyan
Hi Jef!
Best Regards
Jyan
I'M glad I could help you out. You are welcome... and don't forget the code tags, it makes Hulk go green :D
