Results 1 to 3 of 3
    Forum Newbie
    Civil
    AutoCAD 2017
    Jun 2017
    1
    Question distance and elevation routine
    Hi guys,
    Long time ago ,I have written this lisp routine,
    This routine inputs a reference points coordinates, elevation and distance values from screen. It calculates several new points elevation and distance values and writes their elevation and distance values on screen.
    Can anyone help me compiling this routine in to vba code
    (defun C()
    ;We define the reference point
    (command "osnap" "int")
    (setq prop (getpoint "Define the reference point:"))
    (setq propx (car prop))
    (setq propy (cadr prop))
    (setq n 100)
    ;We define the reference point elevation
    (setq ropkot1 (entget (setq ropkot (car (entsel "\n Define the reference point elevation:")))))
    (setq ropkot2 (cdr (assoc 1 ropkot1)))
    (setq ropkoti (atof ropkot2))
    ;We define the reference point distance
    (setq ropmes1 (entget (setq ropmes (car (entsel "\n Define the reference point distance:")))))
    (setq ropmes2 (cdr (assoc 1 ropmes1)))
    (setq ropmesi (atof ropmes2))
    ;We pick up the new point
    (repeat n
    (command "osnap" "end")
    (setq p1 (getpoint "Define new point:"))
    (setq p1x (car p1))
    (setq p1y (cadr p1))
    (command "osnap" "none")
    (command "color" "white")
    (command "line" (list p1x p1y) (list (+ p1x 1.575) (+ p1y 2.1)) "")
    (command "line" (list (+ p1x 1.575) (+ p1y 2.1)) (list (- p1x 1.575) (+ p1y 2.1)) "")
    (command "line" (list (- p1x 1.575) (+ p1y 2.1)) (list p1x p1y) "")
    (setq m1 (- p1x propx))
    (if (< m1 0) (setq mesafe (+ ropmesi (/ (abs m1) 10))) (setq mesafe (- ropmesi (/ (abs m1) 10))))
    (setq kot (+ ropkoti (/ (- p1y propy ) 10)))
    (command "text" (list (- p1x 3.0) (+ p1y 2.5)) 1.8 0 (rtos kot 2 2))
    (command "text" (list (+ p1x 0.75) (- p1y 7)) 1.8 90 (rtos (abs mesafe) 2 2))
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,097
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,579
    Why convert it if it works ? You can run a lisp from VBA code if thats the problem. Just find some VBA code examples you should be able to work it out.
    Code:
    Dim basepnt, pt1, pt2, pt3 As Variant
    basepnt = ThisDrawing.Utility.GetPoint(, " Pick PIT center ")
    ptxtx1 = CStr(FormatNumber(basepnt(0), 3))
    ptxty1 = CStr(FormatNumber(basepnt(1), 3))
    pt1 = ThisDrawing.Utility.GetPoint(, " Pick 1st point ")
  1. lisp routine to quick select by elevation
    By ktbjx in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th May 2016, 03:49 am
  2. Lisp routine to add surface spot elevation points
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2015, 08:13 pm
  3. lisp routine that will difference in elevation between two points.
    By sigi-19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Apr 2014, 08:10 am
  4. Replies: 5
    Last Post: 21st Sep 2011, 07:17 pm
  5. Routine to project a Curve Wall to Elevation
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Sep 2011, 04:58 am
Tags for this Thread
