Results 1 to 6 of 6
    Full Member
    AutoCAD 2015
    Jul 2016
    31
    Default Elevation Intersecting A Wall
    Hi all!
    Had a quick search but couldn't find my particular problem.
    So I have to do a rear elevation of a property (again because of changes) but the owners have now decided to build a fence, separating the back of the property into two halves (one of which is divided into two halves again).
    Here is the current rear elevation:
    https://ibb.co/ehde8Q
    And I've crudely illustrated the birds eye view below. The blue lines are what has been added. Red corresponds to the plan above:
    https://ibb.co/hRALF5
    So my question is; what should the rear elevation look like now? If the fence was just dividing the yard in two, I could maybe just put a cross section of it where it needs to go. But because they've added another fence at a 90 degree angle, that would obstruct the view of the building.
    I'm not sure what the standard procedure is here and can't find an answer on here or by Googling...
    Any help would be much appreciated!
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,211
    One way is to move the section indicator inside the fence, assuming there is one. Another is to add a note, e.g. "fence not shown for clarity." It's the drafter way.
    breaking AutoCAD on a regular basis since 1991
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Quote Originally Posted by CyberAngel View Post
    Another is to add a note, e.g. "fence not shown for clarity." It's the dafter way.
    Definately not daft, I'd do it that way too. Professionally I come across a lot of details like that even sections running off at odd angles through a building just to get a better view (though I can well see how it confuses some people)
    Full Member
    AutoCAD 2015
    Jul 2016
    31
    Unfortunately it's the fence they are interested in. I'm not sure what a section indicator is, sorry!
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    Here are some images, https://www.google.be/search?q=autoc...=1846&bih=1024
    In your case it may be best to add a view for in front and behind the fence.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Perhaps you should draw both an "Elevation" of the building only, and then a "Street View" which would include the fence, but hide building details.
    I am assuming that the fence does not run against the building.
  1. I wnat to aplay the Photo as a wall paper to a round wall .
    By Gali in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Nov 2016, 08:37 pm
  2. Wall Merge issue - Infill wall area for presentation purposes
    By tplight in forum Architecture & ADT
    Last Post: 20th Jun 2014, 04:24 pm
  3. Replies: 2
    Last Post: 5th Mar 2014, 03:31 am
  4. Wall Elevation using Golden Section
    By Elodie in forum AutoCAD Beginners' Area
    Last Post: 22nd Oct 2011, 06:00 pm
  5. Routine to project a Curve Wall to Elevation
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Sep 2011, 04:58 am
