I am hoping for some help as to why my LISP wont work, I have a heap of text saying things like 29.999, 27.999 etc. which I need changed to 30.00, 28.00 etc.
I am trying to use the following but cant get it to work. See lisp below
;ROUND TO 5
(defun c:Rnd5(/ a n index b d c num newnum d1 b1 len last)
(graphscr)
(prompt "Select numbers to be rounded") (terpri)
(setq a(ssget))
(setq n (sslength a))
(setq index 0)
(repeat n
(setq na (ssname a index))
(setq b (entget na))
(setq d (assoc 1 b))
(setq c (cdr d)) ; text item
(setq num (atof c));converts it to number
(setq num (* 2 num));doubles it
(setq num (rtos num 2 2));rounds off to 2 places
(setq num (atof num));converts it to number
(setq num (/ num 2));divides by 2
(setq newnum (rtos num 2 3));rounds off
(setq len (strlen newnum))
(setq last (substr newnum len))
(if (= last "0") (setq newnum (rtos num 2 2)))
(setq d1 (cons(car d)newnum))
(setq b1(subst d1 d b))
(entmod b1)
(setq index (+ 1 index))
(print)
(defun round (num near)
(* (fix (/ (+ num (/ near 2.0)) near)) near)
