Lisp For PDF in portrait is OK but in landscape is not fully plotted?
I am using the below LISP to plot PDF.
I use the same code for portrait ("P" instead of "L") the PDF comes out ok.
The problem is for landscape, the PDF comes out in a smaller plot area such that all 4 side part of the drawing is not plotted.
Why is that?
(defun C:PL ( / cmd file )
   (setq cmd (getvar 'CMDECHO))
   (setvar 'CMDECHO 0)
       (command
           "_.-plot"
           "Y"
           "DWG To PDF.pc3"
           "ISO expand A4 (297.00 x 210.00 MM)"
           "M"
           "L"
           "N"
           "W"
           "1=1"
           "C"
           "Y"
           "PDF.ctb"
           "Y"
           "N"
           "N"
           "N"
           "N"
           "Y"
   (setvar 'CMDECHO cmd)
Perhaps change "1=1" to "Fit" ? and your window coordinates , where do they come from , I only see "" "" (two enters). So perhaps use extends?
gr.Rlx
My money is on RLX answer use hard coded pts these can be outside plot area then use the "C" option centre sometimes you need just a mm or two to get that last line to work. Also Tharwats landscape or portrait.
"A3" "m"  "LANDSCAPE"  "N"   "W"  "-6,-6"  "807,560" "1=2"  "C"
