Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Revision Cloud
    Senior Member
    nicolas's Computer Details
    Windows 7
    Intel Dual Core 64 Bits
    2 GB
    AutoCAD 2015
    Jan 2008
    Rose Hill, Republic of Mauritius
    420
    Default Revision Cloud
    Hi,
    I want to have a revision cloud that fits within the original rectangular object boundary. Example: a rectangle 3000x900 with a Revcloud of arc min and max 200 and 300 will normally have the curves outside the limit of the rectangle. Is there a way to make the whole revision cloud fit within the rectangle 3000x900?
    Thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Offset the rectangle then REVCLOUD it?
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Yes one way of doing it is by offset. For example I have done a revcloud with arc legth = 300 which is actually chord length. I latter measure the height of the arc and found it to be 80. Working back, I was able to fit the revcloud in the rectangle by offsetting it inward at 80. How do we get the height of the arc at 80, diameter at 365 and angle of arc 110 degree. But is there a better way of doing it?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    What is this preoccupation with the size of your revclouds? I fail to understand what difference it makes.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    This is the only way I know to get a reasonable looking rev. cloud as long as you need to have arcs of a specific size. It took me about 5 minutes to make one, something I won't be repeating.
    You could use ARRAYPATH around a rectangle using one POLYLINE arc drawn to a specific set of properties. Warning!! Math required. Each length of each side of the rectangle will have to be a multiple of the cord length. Then you will have to manipulate the resulting array to get the spacing exact. THEN you will have to explode the array because, for some reason, the last arc at a corner will not turn the corner. It should be the first arc on the next side but it won't go. Then you have to rotate the four errant arcs. At this point you can JOIN all the arcs or not.
    That's the thing about autoCad, there's always a way to consume a lot of time if you want to bad enough.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Did you pay that much attention to detail when you had to draw a revcloud manually?
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Personally, I have never cared, just exercising here. When I need a revcloud, I don't even bother to choose the automatic neatness of the rectangular option. As long as the whoopteedoos are big enough to be seen, I am happy.
  8. #8
    Junior Member
    AutoCAD 2013
    Jan 2013
    20
    I see lots of people asking for lisp for Rev cloud, creating or modifying, but rare they ask for deleting them.
    I wanna ask is there a fast way to erase all Rev cloud in a drawing?
    All property of the clouds are vary, layers, sizes, arc length, model space paper space..
    I wondering why the Filter command is not up to this task, am I the only one who always deal with the clouds seas?
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    The filters don't work because a revcloud is simply a polyline made up of arcs. They need a completely unique characteristic before QSELECT or SELECTSIMILAR will work without sucking up all the other polylines.
  10. #10
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    320
    *If* one cared enough, this could probably be set up as a dynamic block - have a vertical and horizontal linear doodad, each of which is tied to a pair of arrays of an arch...
    dJE
    Quote Originally Posted by Dana W View Post
  1. Revision Cloud Help on Sheet
    By drewbranson10 in forum Revit General
    Last Post: 16th Oct 2015, 07:09 pm
  2. new linetype for revision cloud
    By mabo86 in forum Student Project Questions
    Last Post: 24th Oct 2012, 11:40 am
  3. Revision Cloud line weight
    By darrellk-1 in forum AutoCAD General
    Last Post: 7th May 2009, 12:38 am
  4. Revision Cloud
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 23rd Oct 2008, 03:53 pm
  5. inverse revision cloud
    By Scale in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2007, 04:02 pm
Tags for this Thread
