autocad lisp to create lines by typing point names.
withyou
hello
i am looking for a lisp that can create lines or pline by typing point names.
i have the points in my autocad file as blocks attribute with name for each point.
any idea ?
please see attached file
This should do what you ask
(defun c:plbtwnpoints (/ blockSS)
 ;; Get Attribute Value  -  Lee Mac
;; Returns the value held by the specified tag within the supplied block, if present.
;; blk - [vla] VLA Block Reference Object
;; tag - [str] Attribute TagString
;; Returns: [str] Attribute value, else nil if tag is not found.
(defun LM:vl-getattributevalue ( blk tag )
   (setq tag (strcase tag))
   (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att)))
       (vlax-invoke blk 'getattributes)
 (defun Line (p1 p2)
 (entmakex (list (cons 0 "LINE")
                 (cons 10 p1)
                 (cons 11 p2))))
 (if (setq blockSS (ssget "X" (list (cons 0 "INSERT") (cons 2 "CIVIL-0"))))
     (setq nameLatLongList (mapcar '(lambda (x) (list (LM:vl-getattributevalue (vlax-ename->vla-object x) "NAME") (cdr (assoc 10 (entget x))))) (mapcar 'cadr (ssnamex blockSS))))))
 (princ "\nDrawing Line...\n")
 (setq firstpoint (getstring "Enter the name of the first point: "))
 (if (assoc firstpoint nameLatLongList)
   (while (not (eq (setq nextpoint (getstring "\nType the name of the next point: ")) ""))
     (if (assoc nextpoint nameLatLongList)
(line (cadr (assoc firstpoint nameLatLongList)) (cadr (assoc (setq firstpoint nextpoint) nameLatLongList)))
(princ "\nInvalid point. Try again..."))
