This code retrieves object properties.
(defun c:HD (/ ent)
(vl-load-com)
(while
 (setq ent (entsel))
 (vlax-dump-object (vlax-Ename->Vla-Object (car ent)) T)
 ); while
 ); defun
How to get a red string from an dump object?
For the line will be it IAcadLine
Select object: ; [b][color="red"]IAcadLine[/color][/b]: AutoCAD Line Interface
; Property values:
;   Angle (RO) = 0.719545
;   Application (RO) = #<VLA-OBJECT IAcadApplication 000000013ffbc910>
;   Delta (RO) = (209.938 183.961 0.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0000000027cc0bc8>
;   EndPoint = (7714.05 4745.47 0.0)
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "6533"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000000040a107c8>
;   Layer = "0"
;   Length (RO) = 279.133
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 54
;   ObjectID32 (RO) = 54
;   ObjectName (RO) = "AcDbLine"
;   OwnerID (RO) = 50
;   OwnerID32 (RO) = 50
;   PlotStyleName = "ByLayer"
;   StartPoint = (7504.11 4561.51 0.0)
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000000034cd2eb0>
;   Visible = -1
; Methods supported:
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   Copy ()
;   Delete ()
;   GetBoundingBox (2)
;   GetExtensionDictionary ()
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   Offset (1)
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetXData (2)
;   TransformBy (1)
;   Up
Do you want to know what type of object it is?
Use this code to get the DXF code of an object.
(Entget(car(entsel)))
The problem is that there are two different objects at Civil3D in the same name.
These objects are "TIN surface" and "TIN volume surface".
Commandobill Thanks for the reply.
(entget(car(entsel)))
at "TIN surface" returns:
(-1 . <Entity name: 7ffffb2d720>)
(0 . "AECC_TIN_SURFACE")
(330 . <Entity name: 7ffffb039f0>)
(5 . "63B2")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "C-TOPO")
(100 . "AeccDbEntity")
(100 . "AeccDbGeo_aec")
(100 . "AeccDbGeo")
(100 . "AeccDbSurface")
(100 . "AeccDbSurfaceTin")
at "TIN volume surface" returns:
(-1 . <Entity name: 7ffffb2e9a0>)
(5 . "64CA")
(67 . 0)
(410 . "Model")
(8 . "C-TOPO")
(100 . "AeccDbGeo")
If we use
vlax-dump-object
Select object: ; [b][color="red"]IAeccTinSurface[/color][/b]: IAeccTinSurface interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAeccApplication 00000000276536a0>
;   Boundaries (RO) = #<VLA-OBJECT IAeccSurfaceBoundaries 0000000034ffa1d8>
;   Breaklines (RO) = #<VLA-OBJECT IAeccSurfaceBreaklines 0000000034ff7d98>
;   ContourLabelGroups (RO) = #<VLA-OBJECT IAeccSurfaceContourLabelGroups 0000000034ff7cf0>
;   Contours (RO) = #<VLA-OBJECT IAeccSurfaceContours 0000000034ff7f28>
;   DefinitionProperties (RO) = #<VLA-OBJECT IAeccTinSurfaceDefinitionProperties 000000002f4fe2d0>
;   DEMFiles (RO) = #<VLA-OBJECT IAeccSurfaceDEMFiles 0000000034ffa138>
;   Description = "Description"
;   DisplayName (RO) = "Pow 3"
;   Document (RO) = #<VLA-OBJECT IAeccDocument 000000002f4fe5d0>
;   Handle (RO) = "63B2"
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000354be838>
;   Labels (RO) = #<VLA-OBJECT IAeccSurfaceLabels 0000000034ff8240>
;   Layer = "C-TOPO"
;   Lineweight = -1
;   Name = "Pow 3"
;   ObjectID (RO) = 42
;   ObjectID32 (RO) = 42
;   ObjectName (RO) = "AeccDbSurfaceTin"
;   OutputTriangles (RO) = (7065.31 4326.0 53.0 7388.54 4507.73 53.0 ... )
;   OwnerID (RO) = 43
;   OwnerID32 (RO) = 43
;   PointFiles (RO) = #<VLA-OBJECT IAeccSurfacePointFiles 0000000034ff7e88>
;   PointGroups (RO) = #<VLA-OBJECT IAeccSurfacePointGroups 0000000034ff8518>
;   Points (RO) = (7100.66 4689.45 53.0 7388.54 4507.73 53.0 ... )
;   ShowToolTip = -1
;   Statistics (RO) = #<VLA-OBJECT IAeccTinSurfaceStatistics 000000002f4ff0e0>
;   Style = #<VLA-OBJECT IAeccSurfaceStyle 00000000349bc490>
;   StyleName (RO) = "Contours 2m and 10m (Background)"
;   SurfaceAnalysis (RO) = #<VLA-OBJECT IAeccSurfaceAnalysis 000000002f4fe3f0>
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000354be110>
;   Type (RO) = 2
;   Visible = -1
;   AddPointMultiple (1)
;   ArrayPolar (3)
;   Copy ()
;   CreateSnapshot ()
;   Delete ()
;   ExtractBorder (1)
;   ExtractContour (4)
;   FindElevationAtXY (2)
;   GetXData (3)
;   Highlight (1)
;   IntersectPointWithSurface (2)
;   IntersectWith (2)
;   IsReferenceObject ()
;   IsReferenceStale ()
;   IsReferenceSubObject ()
;   IsReferenceValid ()
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   PasteSurface (1)
;   Rebuild ()
;   RebuildSnapshot ()
;   RemoveSnapshot ()
;   Rotate (2)
;   R
Select object: ; [b][color="red"]IAeccTinVolumeSurface[/color][/b]: IAeccTinVolumeSurface interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAeccApplication 000000002f4fc6e0>
;   Boundaries (RO) = #<VLA-OBJECT IAeccSurfaceBoundaries 0000000034ff7348>
;   ContourLabelGroups (RO) = #<VLA-OBJECT IAeccSurfaceContourLabelGroups 0000000034ff77a0>
;   DefinitionProperties (RO) = #<VLA-OBJECT IAeccTinVolumeSurfaceDefinitionProperties 000000002f4fbcc0>
;   DisplayName (RO) = "obj"
;   Document (RO) = #<VLA-OBJECT IAeccDocument 000000002f4fe7e0>
;   Handle (RO) = "64CA"
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000354bd938>
;   Labels (RO) = #<VLA-OBJECT IAeccSurfaceLabels 0000000034ff7110>
;   Layer = "C-TOPO"
;   Lineweight = -1
;   Name = "obj"
;   ObjectID (RO) = 44
;   ObjectID32 (RO) = 44
;   OutputTriangles (RO) = (7226.48 4416.62 53.0 7258.15 4434.42 53.0 ... )
;   OwnerID (RO) = 43
;   Points (RO) = (7189.89 4614.61 53.0 7096.21 4643.67 53.0 ... )
;   ShowToolTip = -1
;   Statistics (RO) = #<VLA-OBJECT IAeccTinVolumeSurfaceStatistics 000000002f4fef00>
;   Style = #<VLA-OBJECT IAeccSurfaceStyle 00000000349ba900>
;   StyleName (RO) = "Contours and Triangles"
;   SurfaceAnalysis (RO) = #<VLA-OBJECT IAeccSurfaceAnalysis 000000002f4fe420>
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000354bd990>
;   Type (RO) = 4
;   Visible = -1
;   ArrayPolar (3)
;   Copy ()
;   CreateSnapshot ()
;   Delete ()
;   ExtractBorder (1)
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   Rebuild ()
;   RemoveSnapshot ()
;   Rotate (2)
;   Rotate3D (3)
;   Sa
Red color means different object names.
An idea to distinguish these objects?
I see several properties that are available for only one of the two object types. So perhaps using vlax-property-available-p can work?
All the examples in the posts can be identified by ObjectName (RO) = "AcDbLine"
(vla-get-objectname obj)
My thoughts aswell...
(defun foo ( o / r )
 (cond
   ( (not (eq 'VLA-OBJECT o)) )
   ( (not (and (vlax-property-available-p o 'ObjectName) (eq (vla-get-ObjectName o) "AeccDbSurfaceTin"))) )
     (setq r
       (if (vl-every '(lambda (x) (vlax-property-available-p o x)) '(Breaklines Contours DEMFiles PointFiles))
         "IAeccTinSurface"
         "IAeccTinVolumeSurface"
 r
