bizzito Posted July 23, 2017 Share Posted July 23, 2017 Hello! I am extracting points coordinates (X,Y) from DXF file. The problems is that there are tens of thousands of points extracted, but I need up to few hundred points. How can I reduce the number of points and segments. The files are exported from Eagle (PCB design) and it is not too complex. I can't export new files with smaller amount of points and lines, but I can work with the DXF files using AutoCAD. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
maratovich Posted July 24, 2017 Share Posted July 24, 2017 Comand line: _overkil Quote Link to comment Share on other sites More sharing options...
bizzito Posted July 29, 2017 Author Share Posted July 29, 2017 Thank you! this definitely works. Quote Link to comment Share on other sites More sharing options...
