Results 1 to 3 of 3
    Forum Newbie
    Construction
    AutoCAD 2017
    Aug 2017
    1
    Default Automatic Unique references
    I'm currently just getting to grips with both dynamic blocks, fields and data extraction, and I was having a play trying to figure out how to do the following.
    I want to create a dynamic block which allows me to draw a rectangle, then position it using the block base point, then stretch the rectangle to a any given size. This part is easy. Now I want to take certain measurements from that rectangle, and populate a table with that data including the addition of a quantity column showing all the blocks with identical values. Also not too challenging.
    The next part is where I struggle however. I need to assign each row of the table with a unique reference number, and then I need to take the data out of this reference number column and show it on the rectangle block in the form of a label.
    Alternatively, (but with the same outcome) I need to create a "reference" attribute which compares certain values of the block to other variations of the same block, and then either, applies the same reference as any matching blocks, or gives it a new reference if there are no blocks with identical values.
    Does anyone have any ideas how this could be accomplished? It would save me weeks of my life. FYI I'm using Acad2017
    AutoCAD 2013
    Nov 2011
    5,986
    Welcome to CADTutor ngowans8.
    Check out Lee Mac's incredible selection of lisps on his site, dig deep, as you will be well rewarded.
    http://www.lee-mac.com/programs.html#general
    Lee is the man!
    Thanks Lee!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    Have you looked at Xdata you can add a "id" to say your rectangle then retrieve it later. The other may be to make a block 1x1 and use scale to set the x & y values you can have a atribute but its set to invisible.
  1. Unique CUIs?
    By HydroGuy in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 11th Dec 2015, 03:03 am
  2. Quadrants of a circle in a unique UCS
    By kapat in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Nov 2013, 01:25 am
  3. Make Block Unique
    By JBullseye74 in forum Tutorials & Tips'n'Tricks
    Last Post: 1st Aug 2011, 08:17 pm
  4. unique elevation problem
    By joe51 in forum AutoCAD General
    Last Post: 21st Jul 2010, 03:49 pm
  5. Unique id per element?
    By Karen99 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2006, 01:31 pm
