Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member lulumara's Avatar
    lulumara's Computer Details
    Window 10
    Intel i7
    P&ID
    lulumara's Discipline Details
    Cad Designer/ Draftsman
    P&ID
    Mechanical, Piping draftsman, Structural, Underground electrical distribution designer (civil), Architectural, and more.
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    Unhappy Annotation Problem
    I had a problem with annotation, Our Engineer who is not familiar with AutoCAD made a changes by himself, then when I open it, All Block text got wild I mean all Block texts are small or huge, if you click them they have annotation of all such as scale of 1:1, 1:10,1:201:1000 and more? Now I did some changes but when I open it, it comes back the same-- small and huge Block Texts? Is there any solution on these problems, Thanks in advance. We have to submit dwg files this project in City Permit and to Hydro Company. And also If I do Published it will show up small tect and big text(Block) But if I do single printing it's good to go?
    Jimmy - using AutoCad 2017 and Solidworks 2009
    AutoCAD 2013
    Nov 2011
    6,056
    Not to be a smart-ass, but it would seem that the obvious solution to the problem is to keep those who are not Autocad literate from working on the drawings.
    Might you have an earlier .bak file available, which you can access and put back into service?
    You only have this problem in one drawing? Do you mean that if you print it/them individually, they look fine?
    If so, that may be the easiest way to go, very hard to know without actually seeing the .dwg file or files.
    No matter how you solve it, clearly the engineer needs to be made aware of the problem his involvement has created, lest it happen again.
    Window 10
    Intel i7
    P&ID
    P&ID
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    This is not the first time He(Engineer) used the AutoCad 2018 to Modified our drawings, He just a Stupid Junior Engineer , sorry for my wordings, I sent a message to the Owner of the company that he should not be working with this kind of work, He should be working in designing. If I gonna open the back up files BAK file it will be a more work for me because I had Modified a lot of the designed he made, the Senior Engineer just gave me the mark ups and I did changed all of he's Design so I cannot use the BAK file . I can print it individually after I changed all Blocks Texts but if I gonna use the command PUBLISH , it will not let me print a good drawings , All texts were scattered and small texts. These drawings have 8 sheet, which is very tedious work. All drawings were a huge messed. I can't attached the files here because it's company Policy and confidential. I 'm thinking of saving as in 2017 because I did read some of the Problem here are kinda matches what happen to my drawings. AutoCad 2018 have a BUG. Or just that the Engineer really don't know what he's doing?
    I hope someone can help me Thanks.
    AutoCAD 2013
    Nov 2011
    6,056
    Your signature says that you are suing 2009 LT, perhaps you should change that, as it sounds like you are using 2018?
    Glad you told the owner.
    Should you want to save as Autocad 2013, try doing it on a COPY or copies of your drawings, just to err on the side of caution.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Check where you set your temp files to be written to it may be deep under your \user\xxx etc but you may find a lot of .bak files you can rename these to .dwg and open, we have our temp set to c:\acadtemp easy to find and clean up.
    Use wblock and just cut a bit of the problem dwg without to much compnay info, else use copy clipboard and paste to a default Autocad template we need to see what he has screwed.
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,216
    Quote Originally Posted by Dadgad View Post
    Around here they call this a "teachable moment." If the engineer is going to keep interfering this way, he needs to know what he's doing. Management should understand that he's causing as many problems as he's solving. Find out how he messed up the annotation and show him how to do it correctly.
    breaking AutoCAD on a regular basis since 1991
  7. #7
    Window 10
    Intel i7
    P&ID
    P&ID
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    Yes I did save as to 2013 and open it in Version 2017 that's solved the Problem looks like 2018 Version had a Bug in it? But if I go in Model space there's still some texts that are still small and big as well. But if I Publish , there's no more problem it maintains it's heights. Thanks.
  8. #8
    Window 10
    Intel i7
    P&ID
    P&ID
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    Don't want to teach a hard headed Engineer, but this afternoon He just heard my side about Annotation Scale that It must be in gray color or Off before changing all the text or copying and modifying it. he might get what I talking about.
  9. #9
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by lulumara View Post
    He might have gotten it, but just in case he didn't, I would suggest that you keep a safety file in a different folder from the one which he might open, in your absence.
    In that way, should he mess up another time, you still have a workable file saved as a backup, in a location where he won't be going fishing for files to mess up.
    Better safe than sorry.
    If he messes you up once, shame on him, if he does it twice, shame on you.
    Glad you seem to have gotten back on the tracks.
  10. #10
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I place my completed files on the server, but I work on my local drive, and every week or so I copy everything to my personal network folder, so if some yahoo messes up one of my drawings, I have a backup. This doesn't apply to any drawings I haven't personally worked on, though in theory, IT should have these backed up as well.
    A .bak is useless if they save the drawing more than once, you would have the same problem to clean up as in the .dwg.
    One place I worked, the files were only accessed fully by one or two people on the network, so you would have to do a Save-As to your Local drive, then they had a folder on the network for them to approve any changes.
  1. 3d annotation
    By macsee in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Mar 2014, 02:57 am
  2. annotation ?
    By richard3009 in forum AutoCAD General
    Last Post: 27th Feb 2014, 04:07 pm
  3. problem with annotation scale in the model space
    By Qonfire in forum AutoCAD Beginners' Area
    Last Post: 4th Apr 2011, 07:50 pm
  4. Annotation problem in opening file
    By iskalipsi in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jul 2010, 05:50 pm
  5. Annotation
    By vertical horizons in forum Autodesk Inventor
    Last Post: 31st Mar 2010, 01:31 am
Tags for this Thread
