Results 1 to 5 of 5
    Junior Member
    AutoCAD 2008
    Mar 2008
    17
    Default VBA - information on selection
    Hello,
    Q1: How do I get the number of entities in a selection using VBA?
    Q2: What is the command/method to find the type of each entity in a selection using VBA?
    Thank you
    Full Member
    AutoCAD 2010
    Oct 2013
    78
    A1: use .Count method of SelectionSet object
    A2: you could use typeOf() like:
    Code:
    If typeOf acEnt Is AcadLine then
    and the likes where acEnt is some AcadEntity type variable you're looping through SelectionSet with
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,477
    Heres my example-attempt:
    Code:
    Sub test() 'define a named function
      'Filter for circles - I don't know how to implement this type of filtering:
      'Dim gpCode(0) As Integer
      'Dim dataValue(0) As Variant
      'gpCode(0) = 0
      'dataValue(0) = "Circle"
      Dim SS As AcadSelectionSet 'Declare "SS" variable as local
      Set SS = ThisDrawing.SelectionSets.Add("NewSS") 'create a new selection set object [include it in the "SelectionSets" collection]
      SS.SelectOnScreen 'select the objects to change (invoke the "SelectOnScreen" method)
      For Each Entity In SS 'iterate over the selection set
        If Entity.ObjectName = "AcDbCircle" Then 'Filter for circles by objectname
          Entity.color = 1 'change entity's colour
        End If
      Next 'process the next entity
      MsgBox SS.Count 'alert the total selected amount of objects
      SS.Delete 'delete the selection set object [exclude it from the "SelectionSets" collection]
    End Sub
    I'm just starting to learn about VBA, so any inputs are appreciated.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Grr this may be usefull
    Code:
    Dim FilterDXFCode(0) As Integer
    Dim FilterDXFVal(0) As Variant
    FilterDXFCode(0) = 0
    FilterDXFVal(0) = "INSERT"
    'FilterDXFCode(1) = 2
    'FilterDXFVal(1) = "SCHEDTEXT"
    Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    for circle
    FilterDXFVal(0) = "CIRCLE"
    lisp (0 . "Insert")
  5. #5
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,477
    Thanks BIGAL!
    This second shot worked:
    Code:
      'SS.Select acSelectionSetWindow , , , FilterDXFCode, FilterDXFVal '<<< BIGAL's example
      SS.SelectOnScreen FilterDXFCode, FilterDXFVal 'select the objects to change (invoke the "SelectOnScreen" method) and include filters
    End Sub
    It seems hard for me to get use with VBA, from lisp (since the lack of syntaxes).
    First Impressions are that VBA and Visual Lisp (not Vanilla) are related, you have to, create a Selection Set Object, invoke a method and iterate thru it - instead of a single ssget function, that would be enough in vanilla lisp (altho still requires iteration).
    With Visual Lisp it would wook like this:
    Code:
      (lambda ( / SS )
        (vla-SelectOnScreen
          (setq SS (vla-Add (vla-get-SelectionSets (vla-get-ActiveDocument (vlax-get-acad-object))) "NewSS"))
          (vlax-safearray-fill (vlax-make-safearray vlax-vbinteger '(0 . 0)) '(0))
          (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 0)) '("CIRCLE"))
        (vlax-for o SS (vla-put-Color o 1))
        (vla-Delete SS)
    P.S. Sorry for late reply - I'm busy with other kind of work (computerless).
  1. Break Down Selection Set into smaller selection sets
    By broncos15 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2017, 03:33 am
  2. Create secondary Selection Sets from first Selection Set...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2012, 10:39 am
  3. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  4. Replies: 1
    Last Post: 18th Nov 2010, 01:56 pm
  5. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
Tags for this Thread
