himal Posted August 18, 2017 Share Posted August 18, 2017 Please help to me create auto lisp for wiring attached below picture.this is socket outlet wiring Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted August 18, 2017 Share Posted August 18, 2017 Please help to me create auto lisp for wiring attached below picture.this is socket outlet wiring [ATTACH]61979[/ATTACH] a bit similar like dynamic array command? (as seen in youTube) but not sure ac2012? no respond due to it's weekend or "please help to do something.."? i'm not electrical related , in ac2007 something like command MEASURE with aligned block Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 19, 2017 Share Posted August 19, 2017 You need two routines straight and corner, drawing a pline is feasible between 2 pick points. I would do a always clockwise as it saves a pick wire direction and you get used to it. Do not have anything at moment some else may have this done. Interesting why does the wire go through the room or is implying up and over in the walls in this case a 3rd option. Quote Link to comment Share on other sites More sharing options...
isutheparambil Posted August 19, 2017 Share Posted August 19, 2017 You may check this... Hope will helpful..... http://www.cadtutor.net/forum/showthread.php?36112-Electrical-Wiring-Lsp Quote Link to comment Share on other sites More sharing options...
himal Posted August 28, 2017 Author Share Posted August 28, 2017 thanks for your reply Quote Link to comment Share on other sites More sharing options...
