ankurpraja Posted August 18, 2017 Share Posted August 18, 2017 Hello, I am working on an iLogic form where i can define the size of a gusset plate as shown in the picture. I am stuck at one point where i want a combo box in ilogic form with 3 options (chamfer, fillet and hole). And that will define which feature is active and make other 2 features suppress. Making a combo box is not a big deal but I am not able to find an ilogic rule where i can say that 'if feature A is active then feature B and C are suppressed. Any solution for above? Thanks in Advance Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 19, 2017 Share Posted August 19, 2017 Whilst this is inventor in Autocad DCL I would use 3 radio buttons these can be made that as you select another the other button is turned off. You should be able to fit 3 easy. Quote Link to comment Share on other sites More sharing options...
twdant Posted October 16, 2017 Share Posted October 16, 2017 Something like this should work: 'suppress all 3 features at first Feature("Feature A").IsActive = False Feature("Feature B").IsActive = False Feature("Feature C").IsActive = False 'activate relevant feature Select oFeature Case A Feature("Feature A").IsActive = True Case B Feature("Feature B").IsActive = True Case C Feature("Feature C").IsActive = True End Select Quote Link to comment Share on other sites More sharing options...
