+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Discipline
    Facilities Mgmt
    Using
    AutoCAD 2010
    Join Date
    Aug 2017
    Posts
    1
    Default Checking standards for layers
    I received a drawing and need to convert the layers to our standard layers. When I use the Check Standard button, only the Dimstyle come up. How do I change the layers?
  2. #2
    Luminous Being RobDraw's Avatar
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,173
    Default
    Layer translator is great for this.
    Drafting is a breeze.
  3. #3
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    5,986
    Default
    Welcome to CADTutor Skelly1951.
    Rob Draw right on the money.
    LAYTRANS is the command, you can create and save the mapping, in case you need to use it another time, say for another drawing from the same vendor.
    Volume and repetition do not validate opinions forged in the absence of thought.
Similar Threads
  1. CAD standards USA national cad standards
    By issammm in forum CAD Management
    Last Post: 24th Feb 2015, 09:56 am
  2. On error checking...
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2014, 09:48 pm
  3. Layers standards
    By henryCADuser in forum CAD Management
    Last Post: 27th Mar 2014, 05:18 am
  4. Need help on Checking a selection set
    By pryzmm in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Nov 2011, 02:50 pm
  5. VBA - Checking for locked layers!!!
    By hardwired in forum .NET, ObjectARX & VBA
    Last Post: 16th Nov 2011, 01:22 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
