LISP modification request...
subdVision
Hi all,
I came across a LISP routine that freezes the layer of any selected object. It works great but I want it to viewport freeze layers, not freeze for the entire drawing.
This is where I found it:
http://forums.augi.com/showthread.php?78426-Special-Layer-Freeze-LISP-Routine
and this is the code I'd like to have modified: (the code wrap button doesn't seem to work)
(defun c:LFR (/ CLayer$ EntList@ EntName^ Layer$)
(setq CLayer$ (getvar "CLAYER"))
(princ "\nSelect object on layer to freeze")
(if (setq EntName^ (car (entsel)))
(setq EntList@ (entget EntName^))
(setq Layer$ (cdr (assoc 8 EntList@)))
(if (and (= Layer$ CLayer$)(/= Layer$ "0"))
(command ".LAYER" "T" "0" "U" "0" "ON" "0" "S" "0" "")
);if
(if (= Layer$ "0")
(princ "\nCannot freeze layer 0.")
(command ".LAYER" "F" Layer$ "")
);if
);progn
);if
);defun c:LFR
[code]
I also attached the actual .LSP file to make it easier.
LFR.LSP
