GREETINGS EVERYONE ;
i am looking for a method to set the annotative block property to "NO"
without using the bedit command
i tried :
(vla-put-Annotative (vlax-ename->vla-object (car (entsel))) :vlax-false)
but it gave this error :
error: ActiveX Server returned the error: unknown name: Annotative
there is a routine to change block properties written by Ian_Bryant
(defun set-block-prop (blkname property value)
(vl-load-com)
(not
(vl-catch-all-apply
'vlax-put-property
(list
(vl-catch-all-apply
'vla-item
(list
(vla-get-blocks
(vla-get-activedocument
(vlax-get-acad-object)
blkname
property value
i tried
("my-block-name" 'annotative 0)
and
("my-block-name" 'annotation 0)
and
("my-block-name" "annotation" 0)
and all the above variations gave me "nil" and did nothing ...
any help will be appreciated
thanks and best regards
Consider the following function:
;; Annotative Block  -  Lee Mac
;; Sets the annotative property for a block definition
;; blk - [str] Block name
;; flg - [bol] Boolean flag (T=Annotative, nil=Not Annotative)
;; Returns: T if successful, else nil
(defun LM:annotativeblock ( blk flg )
   (and (setq blk (tblobjname "block" blk))
           (regapp "AcadAnnotative")
           (entmod
               (append (entget (cdr (assoc 330 (entget blk))))
                   (list
                       (list -3
                           (list
                               "AcadAnnotative"
                              '(1000 . "AnnotativeData")
                              '(1002 . "{")
                              '(1070 . 1)
                               (cons 1070 (if flg 1 0))
                              '(1002 . "}")
Example:
(LM:annotativeblock "F1" nil)
Hi Lee,
I have one question:
If you had to use activex to achieve the same result, does that mean that you'd have to invoke the GetExtensionDictionary method and dig into there?
In other words, anything that has to do with XDATA / GroupCode -3, shall be accessed with the above method, correct?
:unsure:
worked like a charm ... thanks lee
Excellent - you're welcome handasa.
Some tasks lend themselves to the use of Vanilla AutoLISP, but if I were forced to tackle this using ActiveX, I would modify the block definition xdata in the same way using the ActiveX getxdata & setxdata methods.
using manual turn off through block editor and then check block is annotative by this routine
;; by Ian Bryant
;; Return T if ename is annotative, otherwise nil.
(defun IsAnnotative (e)
(and e
(setq e (cdr (assoc 360 (entget e))))
(setq e (dictsearch e "AcDbContextDataManager"))
(setq e (dictsearch (cdr (assoc -1 e)) "ACDB_ANNOTATIONSCALES"))
(assoc 350 e)
) ;end
give nil
while after using your routine , lee to turn off annotative property ... the routine above still read the block as annotative
Thanks Lee,
I've forgot that these methods exist. :ouch:
