Results 1 to 10 of 10
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default Design Center - New Palette Tab
    Hello,
    I wanted to run this by someone before I go ahead and mess around in design ctr. I researched online about creating palettes and they told me to follow procedure I attached. I just opened tool palette instead and right clicked a tab and created a new tab. I have a folders with blocks. I just drag and drop them in there. When I start a new dwg my palette still has my added tab. Is that procedure ok or do I have to go into design ctr instead. Only way I could make a tab in design ctr was by right clicking on design ctr folder. Then design tab showed. I know its in a sample folder but really do not like messing around in there.
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    not sure what happen to attachment. looks pretty bad
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Upload the full sized image to a site such as IMGUR, then share the link here.
    R.K. McSwain
    CAD Panacea | twitter
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    picture is not even necessary I was here > C:\Program Files\Autodesk\AutoCAD 2018\Sample\en-us\DesignCenter.
    If I right click design center folder and make new palette it makes a new tab on autocads tool palette. I just want to know why not just right click tool palette and make new tab and drag/drop your own dwg and/or blocks into it from your own folder libraries. I know nothing about design center and that whole region. THen I see its stemming from the sample folder. I probably do not even want to be in sample, or do I?
  5. #5
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    autodesk directions were to right click design center folder thats why i ask. Might lead to question 2, should i even pay attention to autodesk knowledge site or utilize these type places
  6. #6
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,317
    If you right click in the tool palette you can create an empty palette which you can then manually populate with whatever content you want to add.
    If you right click on a folder in Design Center you can create a new palette which will automatically contain all the content residing within that folder.
    It just depends on which way you want to go about creating new palettes. https://knowledge.autodesk.com/suppo...4FFBD-htm.html
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  7. #7
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Ok, I was just more worried about if it will stay on palette or not. Thinking only way it would stay would be inside autocads folders. Seems like that is not the case.
    thanks
  8. #8
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    I use the right click on the toolpalette usually. With the right click is also the option to customise palettes, which opens another dialogue where you can add palette groups and move and copy tabs between groups. If you are going to be using palettes a lot then it is well worth getting to know.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  9. #9
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default palette2
    Quote Originally Posted by steven-g View Post
    Hopefully,
    We should be in sync. I been using cad for awhile and palettes blew a few people to retirement. I love palettes. However, I have no idea what you are talking about. I just learned that i can just right click for my own tab and add blocks/dwgs. I do not know a palette group. I will research but sometimes well said by insiders!
  10. #10
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    I learned that wblocks can get put into palette and inserted and editing them will not edit copies of it. Whereas blocks will change all around, minus if you make it dynamic. I would like more than one block in a dwg so I do not have a dwg for each bock. Not really sure how to approach this. As of now I am just making folders with wblocks saved there of similarity. If I am missing the scope can someone let me know. I try searching internet and keep getting same old answer of block vs wblock.
  1. Design Center???
    By Honda Matt in forum AutoCAD General
    Last Post: 16th Dec 2010, 02:34 pm
  2. Changing colors in Palette Groups or Design Center
    By kingdaddy in forum AutoCAD General
    Last Post: 15th May 2009, 08:03 pm
  3. Design Center Has Nothing in it!!!
    By dhfh in forum AutoCAD General
    Last Post: 16th Apr 2009, 03:14 pm
  4. Design Center
    By D7CAD in forum AutoCAD Drawing Management & Output
    Last Post: 5th Oct 2007, 10:04 am
  5. design center
    By lulumara in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jul 2006, 11:02 pm
