Results 1 to 7 of 7
Thread: Caliper fun
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Default Caliper fun
    Hello people!
    Today I realized that AutoCAD is just waiting on my hard disc, so I started it and I wrote a short Lisp program.
    If someone wants to play: load the lisp and start it by typing TESTME in the command line. Probable you will have to double click with the wheel to get the zoom to the right place. You should see a caliper open at a random dimension. All you have to do is to read the caliper and enter the value. The command line should show at least 3 lines to see the result. Want to play again? Press enter.
    While AutoCAD waits for your input, you may use the mouse to zoom/pan. Or if you want to cheat, you can measure the opening of the caliper and enter the measured value.
    Have fun!
    Code:
    (defun c:TestMe()
      (if (not (tblsearch "BLOCK" "SublerA")) (MakeBlockA))
      (if (not (tblsearch "BLOCK" "SublerB")) (MakeBlockB))
      (if (not (ssget "X" (list '(0 . "INSERT") '(2 . "SublerA")))) (entmake (list '(0 . "INSERT") '(2 . "SublerA") '(10 0 0 0))))
      (if (not (ssget "X" (list '(0 . "INSERT") '(2 . "SublerB")))) (entmake (list '(0 . "INSERT") '(2 . "SublerB") '(10 0 0 0))))
      (setq measured (/ (rem (getvar "millisecs") 1500) 10.0))
      (setq entl (entget (entlast)))
      (setq entl (subst (list 10 measured 0 0) (assoc 10 entl) entl))
      (entmod entl)
      (setq entered (getreal "Enter measured value "))
      (princ (if (= measured entered) "Ok " (strcat " Not Ok! The answer is " (rtos measured) )))
    (defun MakeBlockA()
      (entmake (list '(0 . "BLOCK") '(2 . "SublerA") '(10 0.0 0.0 0.0)'(70 . 0)))
      (setq i 0)
      (repeat 151
        (cond
          ((= (* 5 (/ i 5)) i) (progn
                     (setq m 0.5)
                     (entmake (list '(0 . "text") (list 10 i 2.6 0) (cons 1 (itoa i)) '(40 . 1.4) (cons 50 0.7)))
        (entmake (list '(0 . "LINE") (list 10 i 0 0) (list 11 i (+ 1.5 m) 0)))
        (setq i (1+ i) m 0)
      (setq points (list '(-3 0 0) '(170 0 0) '(170 8 0) '(-10 8 0) '(-10 -15 0) '(-5 -25 0) '(-5 -30 0) '(-3 -30 0)))
      (setq p1 (list -3 -30 0))
      (foreach p points
        (entmake (list '(0 . "LINE") (cons 10 p1) (cons 11 p)))
        (setq p1 p)
      (entmake (list '(0 . "ENDBLK")))
    (defun MakeBlockB()
      (entmake (list '(0 . "BLOCK") (cons 2 "SublerB") (list 10 0.0 0.0 0.0)'(70 . 0)))
      (setq i 0)
      (repeat 11
        (cond ((= i (* 5 (/ i 5))) (progn (setq n -0.5)
                     (entmake (list '(0 . "text") (list 10 (- (* 0.9 i) 0.5) -5 0) (cons 1 (itoa i)) '(40 . 1.4) (cons 50 0)(cons 62 1)))
        (entmake (list '(0 . "LINE") (list 10 (* 0.9 i) 0 0) (list 11 (* 0.9 i) (+ -2 n) 0)(cons 62 1)))
        (setq i (1+ i) n 0)
      (setq p1 '(-3 -30 0))
      (setq points (list '(-3 0 0) '(15 0 0) '(15 -7 0) '(4 -7 0) '(4 -15 0) '(-1 -25 0) '(-1 -30 0) '(-3 -30 0)))
       (foreach p points
        (setq p1 p)
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,408
    Great fun! Superb program fuccaro, and nice to see you posting again! - I hope all is well.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,592
    Welcome back
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,877
    Welcome back! Nice program!
  5. #5
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Many thanks for your welcome messages, I hope you are well too!
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Very cool program!
    BTW note that the progn functions are redundant, since cond evaluates all expressions after the test one.
    I think it would be funny to implement grread to use that caliper for "measuring", but thats another type of program.
  7. #7
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    Thanks for that PROGN thing -I will try to remember that for the future.
  1. Replies: 4
    Last Post: 13th Feb 2007, 03:45 pm
Tags for this Thread
