+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Full Member
    Discipline
    Electrical
    Using
    AutoCAD 2016
    Join Date
    Sep 2017
    Location
    Townsville, NQ, Australia
    Posts
    32
    Default How to draw an S bend
    Hello, I am a raw newby, and my class starts next week. Can't wait.
    Can anyone please advise the best way to draw an S curve AoB in the attached drawing? How do you determine the radius of the arcs AO and BO?
    At point B, the curve needs to be a bit more horizontal initially, like at point A. My mistake with the sketch
  2. #2
    Forum Deity SEANT's Avatar
    Using
    AutoCAD 2014
    Join Date
    Aug 2005
    Location
    Rhode Island
    Posts
    2,455
    Default
    The vertical requirement, 't', is specified; is there a similar horizontal requirement?
  3. #3
    Senior Member
    Using
    AutoCAD 2016
    Join Date
    Jan 2012
    Posts
    160
    Default
    Start an arc att "A" with END at "O" and DIRECTION parallel to the horizontal lines, and then do the same from "B". You can also use the kommand BLEND.
  4. #4
    Using
    AutoCAD 2014
    Join Date
    Aug 2005
    Location
    Rhode Island
    Posts
    2,455
    Default
    Ah, yes. Arc - Start, End, Direction is the way to go.
  5. #5
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,017
    Default
    This is a double reverse curve and the formula that applies is relevantly simple you have 3 variables r1 r2 and offset for parallel lines. You can do set r1 what is r2? r1=r2 etc My cheat sheet is at work. I have it on my wish list to do one day but was looking at the more complicated non parallel lines solution. Just need a starting pt, there is also what is the rad for a offset given a length the double must fit between.
    If you look at the diagram you can see the diagonal line intersects the circles.
  6. #6
    Full Member
    Discipline
    Electrical
    Using
    AutoCAD 2016
    Join Date
    Sep 2017
    Location
    Posts
    32
    Default
    Thanks kindly, for all these suggestions. Tried the Arc: Start, End, Direction command and it worked perfectly
  7. #7
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    4,076
    Default
    I would do it another way with some temporary lines. First of all,draw a line between A and B. (If you have the osnap Mid between 2 points then this line is unnecessary.)
    Then draw a line from X to A (X is a point somewhere along the line - use Osnap Nearest). Then start the command Arc, and when the start point is needed, give a null response (i.e. just press Enter or right click). The arc will start drawing from the end of the last line drawn, tangential to that line, i.e. will start drawing from A, tangential to the line A. Draw the arc to the mid point of the line A-B at O (or use the osnap mid between 2 points). Then repeat the arc command by pressing Enter or right click, and again give a null response to specifying the start point. The arc will draw tangentially from the last arc, and finishes at B.
    Erase temporary lines and job is done.
  8. #8
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell OptiPlex 7020
    CPU:
    i7 4790 3.6GHz
    RAM:
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    Graphics:
    AMD Radeon 2GB
    Primary Storage:
    Samsung 480Gb SSD
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2017
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    4,581
    Default
    Use the BLEND command, Tangent for the Continuity option. (This is in plain AutoCAD)
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  9. #9
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    4,076
    Default
    Quote Originally Posted by rkent View Post
    Doesn't BLEND create a spline? Whereas the OP appeared to want two arcs.
  10. #10
    Forum Deity steven-g's Avatar
    Computer Details
    steven-g's Computer Details
    Operating System:
    Win 7
    Discipline
    Construction
    steven-g's Discipline Details
    Occupation
    Draughtsman
    Discipline
    Construction
    Details
    I work in the estimating department of a large building contractor.
    Using
    AutoCAD 2018
    Join Date
    May 2013
    Location
    An Englishman in Belgium
    Posts
    2,086
    Default
    I would just find the centre of the arc, which is the intersection of two perpendicular lines, one perpendicular from point A the other perpendicular from the centre of line Ao
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
Similar Threads
  1. How to bend on an arc?
    By Ardalee in forum Autodesk Inventor
    Last Post: 13th Feb 2012, 06:22 pm
  2. how to draw 3d bend in autocad 2008 version with given elevations
    By srinu_vasu38 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Aug 2011, 09:54 am
  3. bend
    By TonyBorland in forum Autodesk Inventor
    Last Post: 6th Aug 2011, 03:10 am
  4. Help) How can I bend a 3d
    By Mr guiff in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Sep 2010, 11:11 pm
  5. How to bend it...
    By nikhil in forum Autodesk Inventor
    Last Post: 25th Aug 2010, 09:36 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
