Hello,
Odd behavior concerning errno variable and UCS command:
(setvar 'errno 0)
Using "UCS" command, rotate UCS to OBject, selecting nothing:
(getvar 'errno)
...returns 2, as expected.
But with lisp:
(setvar 'errno 0)
 (command "ucs" "ob" pause)
Select nothing, and errno returns 0 still.
Any idea why one would act as expected and the other not?
in 2015 both set errno to 2
Command: (setvar 'errno 0)
0
Command: (command "ucs" "ob" pause)
No object found
nil
Command: (getvar 'errno)
2
weird...
Thanks for checking han and Jef!
I am on 2016, and it consistently returns 2 when issuing command, and 0 through lisp.
if this is a bug in different versions (yours 2016 Jef's 2015 ,2007) etc.. not sure entsel?
I found setting ucs by entity to be somewhat unpredictable.
For instance, setting ucs to a line, the ucs will be different depending where on that line you pick.
Gets even more unpredictable on a polyline or solid.
You're welcome!
I havn't study UCS "object" in depth, but my feeling is that (well, for the machine) it is probably more arbitrary than unpredictable. (like the orientation of the X and Y axes of an OCS, or what part of a 3DSolid will keep the original handle/ename after you slice it in 2, etc).
Hey Jef!
You are probably right on that.
