Bill Tillman Posted September 19, 2017 Share Posted September 19, 2017 I have a 3D model which is a metal assembly embeded in concrete. The rendering looks nice but I was hoping to show more details of the metal which is embedded in the concrete. Short of making the concrete appear as glass I was wondering if anyone has a suggestion on how to achieve this look? Quote Link to comment Share on other sites More sharing options...
f700es Posted September 19, 2017 Share Posted September 19, 2017 You could always do two renders of the same view, one with full textures and one with only the support metal. Then bring both images into Photoshop and apply a gradient layer mask. OK tutorial time.... Render image 1: Render image 2: Open both images in Photoshop: In image 1 create a new layer and copy and paste image 2 into this new layer. Select layer 1 (the new one on top) and then add a layer mask to it. It is the button at the bottom, a square with a circle in it. Now select the gradient tool and select the transparent gradient to use as a mask. Now click and drag to fill in with the gradient tool and you'll get a transparent effect. You might have to undo and redo the fill till you get the look you want. I hope this was what you were looking for Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 19, 2017 Share Posted September 19, 2017 You could always do two renders of the same view, one with full textures and one with only the support metal. Then bring both images into Photoshop and apply a gradient layer mask. Yep, that's how I would do it. Quote Link to comment Share on other sites More sharing options...
lrm Posted September 19, 2017 Share Posted September 19, 2017 Another approach is to create a transparent concrete starting with a generic material. CRank the Glossiness way down and set the Refraction index to 1.0 (air) as a start and use the Autodesk concrete map. This method has the advantage of dealing with objects that may lie in the foreground which of course you can deal with in Photoshop via some masking. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted September 20, 2017 Author Share Posted September 20, 2017 Cool, both of these methods look very interesting. I particularly like the one proposed by IRM. This should take care of the problem of the concrete hiding all the interesting stuff inside of it. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
