+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    May 2015
    Posts
    14
    Default Creating a drawing "info-file"
    For a current project, we need to provide a "info-file" for each dwg file.
    This should be in txt or XLS.
    This information file should at least contain the following info:
    - file-name (+ path maybe)
    - XREF names/info
    - used layers
    - used blocks
    - used ctb-file and printer info/settings
    Someone was allready starting making this manually in excel but this would be a very long work to do for every drawing.
    Can this be done directly in acad of with a lisp routine or something?
  2. #2
    Super Member halam's Avatar
    Using
    AutoCAD 2017
    Join Date
    Jul 2015
    Posts
    658
    Default
    Some direction..
    Search for
    Dwgprops + lisp
    Etransmit (+ lisp) to supply and use the transmital reports .txt with the .zip should be good enough imo
    There are tools to write filesize and names in subdirectories.
    Xrefs and more stuff like that can also be found with the external tool 'reference manager'
    Hope some of these ingrediënts might help you..
    I think designers should not be botherred by some control freaks ;-)
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
Similar Threads
  1. Sheet Metal Cylinder - "Creating" & "Flatten" Question
    By vertical horizons in forum SolidWorks
    Last Post: 10th Jan 2014, 12:15 pm
  2. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  3. Replies: 5
    Last Post: 19th Sep 2013, 03:27 pm
  4. Replies: 1
    Last Post: 4th Oct 2012, 12:40 pm
  5. Replies: 3
    Last Post: 7th Oct 2009, 09:12 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
