gsc Posted September 20, 2017 Posted September 20, 2017 I have 2, equal length, lists with items like: ((x y z) name) Example List 1: (((496502.36 5733207.41 0.0) S4_WTG-H01) ((495332.36 5734422.41 0.0) S4_WTG-H02) ((493742.36 5734362.41 0.0) S4_WTG-H03) ((493427.36 5735207.41 0.0) S4_WTG-H04) ((492132.276311227 5734917.0 0.0) S4_WTG-H05)) Example List 2: (((496502.36 5733207.41 0.0) S4_OSS-H01_CASE2_AP-ORG) ((495332.36 5734422.41 0.0) S4_H01-H02_CASE2_AP-ORG) ((493742.36 5734362.41 0.0) S4_H02-H03_CASE2_AP-ORG) ((493427.36 5735207.41 0.0) S4_H03-H04_CASE2_AP-ORG) ((492300.0 5734917.0 0.0) S4_H04-H05_CASE2_AP-ORG)) I want to compare the 2 lists based on the (x y z) coordinate. how can i get the list1 items ((x y z) name), which xyz coordinates are not matching any of the xyz coordinates of list2? Notes: Both lists might be ordered randomly In the example lists shown, 1 coordinate is not matching for testing purposes I found something like: (vl-remove-if '(lambda (x) (member (x) list2)) list1) with above code, list1 should end up with only the not matching ((x y z) name) items. Now x is ((x y z) name) but I need to compare the (car x) = (x y z). But I read somewhere that it is not possible to check with 'member' if coordinates are (not) equal? Anyone an idea how to approach this? Quote
Lee Mac Posted September 20, 2017 Posted September 20, 2017 Try the following: (defun foo ( lst1 lst2 ) (vl-remove-if (function (lambda ( itm1 ) (vl-some (function (lambda ( itm2 ) (equal (car itm1) (car itm2) 1e- ) ) lst2 ) ) ) lst1 ) ) _$ (foo list1 list2) (((492132.0 5.73492e+006 0.0) S4_WTG-H05)) Quote
gsc Posted September 20, 2017 Author Posted September 20, 2017 Wow...Works like a charm, thanx! Quote
