halam Posted September 24, 2017 Share Posted September 24, 2017 Hi I'm trying to come of with a piece of code which will have the ability to fillet with a given radius regardless if it is a polyline of line. I got this routine working for Rebar bending but it only works on lines. I want to make it "POLYLINE friendly" as well. Here is a piece of code. I get stuck in the part where it decides t is either LINE or POLYLINE. Any help or lead to similar codes is appriciated. ; example for a fixed r=40 handling (defun c:fg16 (/ CMDECHO CMDDIA FRAD E1 E2) (princ "\fillet diam. 16, r = 40 ") (setq ERR *ERROR* *ERROR* LISP-ERR CMDECHO 0 CMDDIA 0 E1 NIL E2 NIL FRAD (getvar "filletrad") ) ;_ end of setq (setvar "filletrad" 40) (setq E1 (entsel "\nSelect first object: ")) (while (/= E1 nil) (progn (setq tipoent (cdr (assoc 0 (entget (car (E1)))))) ; hmmm.. (if (= tipoent "POLYLINE") ; if it is ONE polyline , handle it (command "_.fillet" "_polyline" "radius" "40" E1) ; end for polyline, but it fails (?) (progn (redraw (car E1) 3) ; start part for single LINES (setq E2 (entsel "\tsecond: ")) ; second line needed (redraw (car E2) 3) (command "fillet" E1 E2) (setq E1 (entsel "\nfirst: ")) ) ; end part for single ) ) ) (setvar "filletrad" FRAD) (princ) ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 24, 2017 Share Posted September 24, 2017 Try: (lambda ( / cmd e typ ) (setq cmd (cond (command-s)(vl-cmdf)(command))) (setvar 'errno 0) (while (zerop (getvar 'errno)) (setq e (car (entsel "\nSelect object to fillet <exit>: "))) (cond ( (or (not e) (= 7 (getvar 'errno))) (setvar 'errno 0) ) ( (wcmatch (setq typ (cdr (assoc 0 (entget e)))) "*POLYLINE") (cmd "_.fillet" "_polyline" "radius" (vl-prin1-to-string (getvar 'filletrad)) e) ) ( (= typ "LINE") (cmd "fillet" e "\\") ) ( (alert "Invalid object.") ) ) ) ) Quote Link to comment Share on other sites More sharing options...
halam Posted September 25, 2017 Author Share Posted September 25, 2017 Works like a champ.. Thanks! Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 25, 2017 Share Posted September 25, 2017 Works like a champ.. Thanks! No problem Hans, I'm glad to help! Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted September 26, 2017 Share Posted September 26, 2017 Just a small remark: For predictable results it is better to supply the _Fillet command with the complete entsel list instead of just the ename. (setq lst (entsel)) (command "_.fillet" lst "\\") Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted September 26, 2017 Share Posted September 26, 2017 @Grrr: Looking at the docs I see that pause is not allowed for command-s. Your code suggests that "\\" (the equivalent of pause) is. This seems strange. Have you tested this? Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 26, 2017 Share Posted September 26, 2017 Just a small remark:For predictable results it is better to supply the _Fillet command with the complete entsel list instead of just the ename. (setq lst (entsel)) (command "_.fillet" lst "\\") I was not aware that you could supply the entsel list, thanks! @Grrr:Looking at the docs I see that pause is not allowed for command-s. Your code suggests that "\\" (the equivalent of pause) is. This seems strange. Have you tested this? Yup, I've tested my fragment on ACAD2017 - works fine, just like in Hans's demo. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted September 26, 2017 Share Posted September 26, 2017 @Grrr: Thanks for confirming this. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted September 30, 2017 Share Posted September 30, 2017 @halam: What if the user wants to fillet two polylines? The current code does not allow for that. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted September 30, 2017 Share Posted September 30, 2017 Maybe this: (vl-load-com) (defun c:AltFillet ( / *error* N_Radius N_Select doc entselA entselB) (defun *error* (msg) (setvar 'cmdecho 1) (vla-endundomark doc) ) (defun N_Radius ( / new) (if (setq new (getdist (strcat "\nFillet radius <" (rtos (getvar 'filletrad)) ">: "))) (setvar 'filletrad new) ) ) (defun N_Select (msg / inp) (setq inp T) (while (and inp (not (vl-consp inp))) (initget 128 "Radius") (setq inp (entsel (strcat "\nFillet (radius=" (rtos (getvar 'filletrad)) "): Radius/<" msg ">: " ) ) ) (if (= "Radius" inp) (N_Radius) ) ) inp ) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (setvar 'cmdecho 0) (cond ((not (setq entselA (N_Select "Select first entity"))) nil ) ((vl-position (vla-get-objectname (vlax-ename->vla-object (car entselA))) '("AcDb2dPolyline" "AcDbPolyline")) (if (setq entselB (N_Select "Select second entity or Enter to fillet selected polyline")) (command "_.fillet" entselA entselB) (command "_.fillet" "_polyline" entselA) ) ) ((setq entselB (N_Select "Select second entity")) (command "_.fillet" entselA entselB) ) ) (setvar 'cmdecho 1) (vla-endundomark doc) (princ) ) Quote Link to comment Share on other sites More sharing options...
halam Posted September 30, 2017 Author Share Posted September 30, 2017 @halam:What if the user wants to fillet two polylines? The current code does not allow for that. Because it was meant for 2d rebar detailling it is not likely, either the user starts rebar doing one polyline or multiple single lines. However any improvement is welcome to make a general versitile fillet routine. Which makes me wonder if 3d polylines can be handled accordingly.. (for 3d rebar) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted October 1, 2017 Share Posted October 1, 2017 Which makes me wonder if 3d polylines can be handled accordingly.. (for 3d rebar)Last time I checked 3D polylines could not be filleted. But you probably know that as well... Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 1, 2017 Share Posted October 1, 2017 For 3d polyline : https://www.theswamp.org/index.php?topic=49959.0 (you have to be logged in...) Quote Link to comment Share on other sites More sharing options...
halam Posted October 1, 2017 Author Share Posted October 1, 2017 (edited) Last time I checked 3D polylines could not be filleted. But you probably know that as well... Off course i was not aware, just a dumb AutoCAD user having silly ideas. I must be me missing some deep mathematical reason here ;-) thanks for replying also Marko! Edit: 3Dpolyline could in theory be used for 3D rebar array. attached as a theoretical idea .. ..calculate and add the two points before and after bending, ..add bending parameter.., quadratic bending,..etc. make it 3D.., array.. but i think its all way to complcated to do it with lisp. Workflow for me to work 3d rebar is to just UCS right first and work with 2Dpolylines and work from there. Edited October 1, 2017 by halam Quote Link to comment Share on other sites More sharing options...
