Either input allowed
saim
Is there a way to prompt something like "Click on a polyline with the desired elevation or just type the value" and AutoCad accept either input? How?
What I really want:
- if the user clicks on a polyline, I get the height and set it to variable H1
- if the user types an real value, I set it to the same variable H1
- if the usar clicks anywhere else or types anything but a real value, I understand that as an error and keep the command waiting for the correct input
- if the usar presses esc or enter, exit the command
I use something similar to this quite a lot.
Something like
(Defun c:test ( / docontinue h1 end)
(While (not docontinue)
(Setq h1 (vl-catch-all-apply 'entsel (list "pick polyline or press enter to input value")))
(Cond
((Not h1)
(Setq h1 (getreal "enter value")
         docontinue T
         End nil)
((vl-catch-all-error-p h1)
(setq docontinue T
         End T)
(T (setq docontinue T
              End nil))
(If (not end)
'dosomething
(Print h1)
'else
(Print "You pressed escape")
(Princ)
untested code wrote on my phone but it should give you an idea
You can substitute the entsel for an ssget with ':e:s' and a polyline filter to make it more robust but have a play
Sent from my Pixel XL using Tapatalk
Edited by SLW210
Added Code Tags
Should be able to put them manually, [NOPARSE]
Your Code Here[/NOPARSE]
But now that you mention it, I haven't used Tapatalk in quite some time, I'll look into that.
Thanks! It'll take me a little time reading through the help file to check what some of the commands means, but I should be fine.
The code didn't work as it is right now, but I suppose I should change some stuff in it, right?
One tiny problem is that I didn't want to press enter before entering the value... I wish it was something like the "line" command, where you can either click somewhere to define the second point or just type in the coordinates. Tell me if I'm asking too much, I can live with pressing enter...
If your mainly wanting to enter a value you can use getstring instead of entsel and check the value with the condition statement. I'll be able to get in the computer later and test something if your stuck.
Use [noparse](initget 128)[/noparse] to allow arbitrary input - here is a quick example:
(defun c:test ( / rtn )
   (while
       (progn (initget 128)
           (and (setq rtn (getpoint "\nPick a point or specify elevation <exit>: "))
               (not
                   (or (and (listp rtn) (setq rtn (caddr rtn)))
                       (setq rtn (distof rtn))
       (princ "\nThe specified value is not numerical.")
   (if rtn
       (princ (strcat "\nThe user entered " (rtos rtn)))
       (princ "\nThe user did not enter a value.")
Thanks again! That sounds pretty much more like what I have in mind. What I'm meaning to do is getting the topographic height into a variable - either clicking on the level curve, the point text (that comes along with the topography) or by typing it down. I think I'll be able to change the "getpoint" to an "entget" and copy-paste your code.
I'd appreciate if you commented that code, but spending some time crunching on it may help, too. The greatest problem seems to be that I don't know a lot of commands, perhaps just commenting won't help if I don't learn them. I'll do.
...but I'd really like explained what the ( / rtn) part, on the first line, means. I have no idea how to look for it on the manual
Edited by saim
Inside the brackets the left side of the / is for arguments sent to the command, on the right side are localised variables. This means if you set a variable in your code you also place the variable here and once the routine has finished the variables will be set back to nil. It's just a way of tidying up after yourself.
  • 2 weeks later...
There is no "spoiler" wrapping to hide all the rambling I made while typing all my doubts, so I'll wrap it in quote brackets. It might be useful in understanding my doubt.
I figured out a lot about how the code works, but could not fully understand the initget function. I assumed that if I typed anything, instead of clicking, the code would take it as a string. If that was correct, then the following code would work:
(initget 128)
(setq tstvar (getpoint "\nClick an object "))
(setq tstvar (distof tstvar))
Also tried with entget instead of getpoint (which is the final intent, by the way).
When I typed a real value instead of clicking some object, the "bad argument type" error came up and "tstvar" did not receive the inputted value (it received a point, which I can't find out how it was selected).
So... How does initget REALLY work?
Now, the rambling:
I'm diggin. Can't tell why it works (but it sure does!). I'll try to write this in pseudocode. Please tell me where I'm wrong.
(initget 128)
Allow either input. This seems to be the core of the answer. But I'm having problems in understanding the rest of the code.
"getpoint" Asks the user to click somewhere. I understand that the code will pause here until the user does something. Not sure what would happen when the value is typed in, I'm assuming the program will receive it as a string and the rest of the code will transform it into a real value.
"rtn" is a list and the 3rd element on that list is a value. "rtn" becomes that 3rd element, a.k.a. the height of the point.
I'll call this "statement 1" for further using.
Doubt one: if the user types a value, listp will return "false". Will (caddr rtn) do anything? Tried to run that piece of code to a string and to a real value, both returned errors. Does it still happen during the code or is it skipped, somehow?
"rtn" gets transformed from the user input - a string - into a real value.
I'll call this "statement 2"
Doubt twoo: if the user inputs a click, I understand that at this point of the code, "rtn" would be the height - a real value. Tried (distof 4) and it returned an error (bad argument type). Does this still happen during the code or is it skipped, somehow?
Doubt three: Are errors treated like boolean values (false) by autolisp?
Returns true if either statement1 or statement2 is true.
                (not
Returns false if either statement1 or statement2 is true. Or true, if they are both false.
I'll call this "statement3".
Hmmm... starting to make sense...
               (not
If user inputted anything and it cound NOT be transformed into a real value, then returns true. If it DID get transformed into a real value, returns false. My confusion is because I expected that it returned "true" for the right input and it doesn't. Admitting the other way around clarifies things a little bit.
Initget allows you to enter text when the getxxx command is called. You can then use cond to further test the response from the getxxx call. You can actually give a list of words after the initget, sort of like a filter. Look on Google for 'autolisp initget'.
Hopefully the following explanation will clear everything up:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] rtn )
   [color=GREEN];; Define function, declare local variables[/color]
   ([color=BLUE]while[/color]
       [color=GREEN];; While the following returns a non-nil result[/color]
       [color=GREEN];; Read: "While the user provides some input and the input is invalid"[/color]
       ([color=BLUE]progn[/color]
           [color=GREEN];; Evaluate the following expressions and return the result of the last evaluated expression[/color]
           ([color=BLUE]initget[/color] 128)
           [color=GREEN];; Allow arbitrary input at the next prompt[/color]
           ([color=BLUE]and[/color]
               [color=GREEN];; Return T if ALL of the following expressions return a non-nil value[/color]
               [color=GREEN];; STOP evaluating expressions if an expression returns NIL (short-circuit evaluation)[/color]
               ([color=BLUE]setq[/color] rtn ([color=BLUE]getpoint[/color] [color=MAROON]"\nPick a point or specify elevation <exit>: "[/color]))
               [color=GREEN];; Prompt the user for a point or any text input[/color]
               [color=GREEN];; If the user presses ENTER here or right-clicks, AND will return NIL and the WHILE loop will cease[/color]
               [color=GREEN];; If we've reached this point, the user must have entered something or left-clicked the mouse[/color]
               ([color=BLUE]not[/color]
                   [color=GREEN];; Invert the value returned by the following expression[/color]
                   [color=GREEN];; Read: "While neither of the following are True"[/color]
                   ([color=BLUE]or[/color]
                       [color=GREEN];; Return T if EITHER of the following expressions return a non-nil value[/color]
                       [color=GREEN];; STOP evaluating expressions if an expression returns T (short-circuit evaluation)[/color]
                       [color=GREEN];; Read: "Either..."[/color]
                           ([color=BLUE]listp[/color] rtn)
                           [color=GREEN];; Test whether the value returned by getpoint is a list[/color]
                           [color=GREEN];; Read: "The value is a list (i.e. the user clicked a point)"[/color]
                           ([color=BLUE]setq[/color] rtn ([color=BLUE]caddr[/color] rtn))
                           [color=GREEN];; If so, retrieve the 3rd element (i.e. the Z-coord)[/color]
                       ) [color=GREEN];; end AND[/color]
                       [color=GREEN];; Else 'rtn' is not a list and so must be a string[/color]
                       [color=GREEN];; Otherwise OR would have already returned T and the following would NOT be evaluated[/color]
                       ([color=BLUE]setq[/color] rtn ([color=BLUE]distof[/color] rtn))
                       [color=GREEN];; Attempt to convert the string to a number[/color]
                       [color=GREEN];; This will return NIL if the string is not numerical, causing OR to return NIL, causing NOT to return T, causing the WHILE loop to continue[/color]
                   ) [color=GREEN];; end OR[/color]
               ) [color=GREEN];; end NOT[/color]
       ) [color=GREEN];; end PROGN[/color]
       ([color=BLUE]princ[/color] [color=MAROON]"\nThe specified value is not numerical."[/color])
       [color=GREEN];; If we're here, the user must have entered non-numerical text[/color]
       [color=GREEN];; Inform them and continue the loop.[/color]
   ) [color=GREEN];; end WHILE[/color]
   ([color=BLUE]if[/color] rtn
       [color=GREEN];; If the variable 'rtn' holds a non-nil value[/color]
       ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nThe user entered "[/color] ([color=BLUE]rtos[/color] rtn)))
       [color=GREEN];; Print the value[/color]
       ([color=BLUE]princ[/color] [color=MAROON]"\nThe user did not enter a value."[/color])
       [color=GREEN];; Else notify the user that no [valid] value was entered[/color]
   ) [color=GREEN];; end IF[/color]
   ([color=BLUE]princ[/color])
   [color=GREEN];; Supress the value returned by the last evaluated expression[/color]
) [color=GREEN];; end DEFUN[/color]
Please repay the time I have invested in constructing this explanation by investing the same amount of time reading & studying the comments carefully.
Lee everytime I read something of yours I learn something new. 'Listp' I've always used type = 'list [emoji849]
He is like the best LISP book out there! One can teach alot by reading his posts. :beer:
Perhaps this should clear things about listp :
_$ (listp nil)
T
_$ (type nil)
nil
_$ (eq (type nil) 'LIST)
nil
Note that nil symbol stands for 'empty list', thats why listp returns T.
Checks like (eq (type lst) 'LIST) or (vl-consp lst) will return true only if lst is indeed a list and is not null.
I see, so if the variable cannot possibly be set as nil then use listp else use the eq type method?
In short, yes - Lee did make sure that rtn holds a non-nil value by wrapping it inside the and expression,
(and
then he performed the listp checking, which would mean if rtn is a list indeed - then to retrieve the Z-coord.
Else like he commented:
BTW If you want to avoid type checking, another common way is:
(and lst (listp lst))
Which is equivalent of:
(vl-consp lst)
that I oftenly use.
As for me, everything anyone posts has something new... XP
Thanks a huge bunch for the comments, Lee! I realised I wasn't totally wrong at the rambling, after all, was I?
The STOP evaluation conditions were gold! I would NEVER get to that info by just readind the help file.
So, if (listp rtn) returns false, then (setq rtn (caddr rtn)) won't do anything. If it does, then the rest of the "or" won't try to execute. Brilliant!
I did understand that (initget 128 ) will allow either input... but then, why doesn't that piece of code on my latest post work? This one:
(initget 128)
(setq tstvar (getpoint "\nClick an object "));I will just type a value, like 50
When I typed "50", I expected the tstvar to get that value, like in your code. I didn't test for a click, but since I didn't click, it shouldn't matter.
Other than that, I did a further reading on the help file and it seems that even if it worked, (initget 128 ) does NOT work with the entsel function. The only value that might allow entsel would be... none?
There IS a column in which entsel gets a tick, but it is listed before "bit 0" (in which I should type "1"), so I don't know if it really exists. Furthermore, all the other bits are shown with the input bit value between parenthesis, this one isn't.
Am I doomed to choose between using the initget or entsel?
Thanks all - I'm pleased to see that this thread has evolved into an interesting discussion :thumbsup:
You're most welcome saim - I'm always happy to help those keen to learn.
The branching logic that I've implemented in my example is known as 'short-circuit evaluation' or 'McCarthy evaluation' (after John McCarthy, the inventor of LISP); it's a very useful exploit for writing concise code, but just be aware that other languages (for example VBA) don't offer this form of evaluation.
(initget 128)
Because you have enclosed the three expressions inside outer parentheses, meaning the value returned is then evaluated as a function.
Try instead:
(defun c:test ( / tstvar )
   (initget 128)
   (setq tstvar (getpoint "\nClick an object ")) ;I will just type a value, like 50
   (if (= 'str (type tstvar))
Indeed entsel does not support arbitrary input - you would need to roll your own...
[color=GREEN];; Selection or Text  -  Lee Mac[/color]
[color=GREEN];; Prompts the user to select an object or enter an arbitrary string.[/color]
[color=GREEN];; msg - [str] [Optional] Prompt string[/color]
[color=GREEN];; ftr - [lst] [Optional] ssget filter list[/color]
[color=GREEN];; Returns: [ent/str] Entity name of selected entity or entered string; "" if enter is pressed.[/color]
([color=BLUE]defun[/color] LM:select-or-text ( msg ftr [color=BLUE]/[/color] gr1 gr2 rtn sel )
   ([color=BLUE]setq[/color] msg ([color=BLUE]princ[/color] ([color=BLUE]cond[/color] (msg) ([color=MAROON]"\nSelect object: "[/color])))
         rtn [color=MAROON]""[/color]
           ([color=BLUE]setq[/color] gr1 ([color=BLUE]grread[/color] [color=BLUE]nil[/color] 14 2)
                 gr2 ([color=BLUE]cadr[/color] gr1)
                 gr1 ([color=BLUE]car[/color]  gr1)
               (   ([color=BLUE]=[/color] 3 gr1)
                   ([color=BLUE]if[/color] ([color=BLUE]ssget[/color] gr2) [color=GREEN];; nentselp is slow for xrefs[/color]
                       ([color=BLUE]if[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] gr2 ftr))
                           ([color=BLUE]progn[/color] ([color=BLUE]setq[/color] rtn ([color=BLUE]ssname[/color] sel 0)) [color=BLUE]nil[/color])
                           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nInvalid object selected."[/color] msg))
                       ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nMissed, try again."[/color] msg))
               (   ([color=BLUE]=[/color] 2 gr1)
                       (   ([color=BLUE]<[/color] 31 gr2 127)
                           ([color=BLUE]setq[/color] rtn ([color=BLUE]strcat[/color] rtn ([color=BLUE]princ[/color] ([color=BLUE]chr[/color] gr2))))
                       (   ([color=BLUE]=[/color] 13 gr2)
                       (   ([color=BLUE]and[/color] ([color=BLUE]=[/color] 8 gr2) ([color=BLUE]<[/color] 0 ([color=BLUE]strlen[/color] rtn)))
                           ([color=BLUE]setq[/color] rtn ([color=BLUE]substr[/color] rtn 1 ([color=BLUE]1-[/color] ([color=BLUE]strlen[/color] rtn))))
                           ([color=BLUE]princ[/color] [color=MAROON]"\010 \010"[/color])
                       (   [color=BLUE]t[/color]   )
               (   ([color=BLUE]=[/color] 25 gr1)
   rtn
