abra-CAD-abra Posted October 5, 2017 Posted October 5, 2017 All, I am battling with this error and I cannot find much documentation on it: Error: bad argument type: output-streamp: "C:\\Coords\\test.csv" I cannot see any problems with my code although I suspect it may be something to do with getfiled? Anybody have any suggestions? Please refer attached LISP. Thanks in advance C2Ex.lsp Quote
rlx Posted October 5, 2017 Posted October 5, 2017 You try to write to the file-name (fnm) when you should write to the file-pointer (opn) gr.Rlx Quote
Tharwat Posted October 5, 2017 Posted October 5, 2017 Hi, The error you have been receiving is due to writing to file name and not to file-pointer as Rlx mentioned above, so I rewrote 'your' codes in another way and hope you don't mind since the following code and is more than enough and faster than converting safearray to list and so on. (defun c:test (/ *error* opn s fnm i e ip) (defun *error* (msg) (if opn (close opn)) (and msg (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (and (setq s (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (setq fnm (getfiled "Save Coordinates to Text or CSV File" "" "csv;txt" 1)) (setq opn (open fnm "w")) ) (repeat (setq i (sslength s)) (setq e (vlax-ename->vla-object (ssname s (setq i (1- i)))) ip (vlax-get e 'insertionpoint)) (write-line (strcat (vla-get-textstring (car (vlax-invoke e 'getattributes))) "," (rtos (car ip) 2 4) "," (rtos (cadr ip) 2 4)) opn) ) ) (*error* nil) (princ) ) (vl-load-com) Quote
abra-CAD-abra Posted October 6, 2017 Author Posted October 6, 2017 Thank you for your help guys. Tharwat, I like your alternative solution using vlax-invoke and 'getattributes. Always learning.. Thanks again. Quote
