All solid hatching within blocks color change edit - need help
Good morning all!
I have a code that works perfectly for updating the color to the truecolor 255,255,255 for all solid hatching.
Basically i just need this exact code, except i need it to update the color to ByBlock.
Can anyone help me out?
(defun c:hw (/ doc)
 (or *colorobject*
     (setq *colorobject*
     (vla-getinterfaceobject
       (vlax-get-acad-object)
       (strcat "AutoCAD.AcCmColor." (substr (getvar "acadver") 1 2))
 (if
   (null (vl-catch-all-error-p (vl-catch-all-apply 'vla-setrgb (list *colorobject* 255 255 255))))
    (progn (vlax-for blk (vla-get-blocks (setq doc (vla-get-Activedocument (vlax-get-acad-object))))
      (if (= :vlax-false (vla-get-isxref blk))
	(vlax-for obj blk
	  (if (and (= "AcDbHatch" (vla-get-objectname obj))
		   (= "SOLID" (strcase (vla-get-patternname obj)))
		   (vlax-write-enabled-p obj)
	    (vl-catch-all-apply 'vla-put-truecolor (list obj *colorobject*))
    (vla-regen doc acallviewports)
(vl-load-com)
(defun c:hw (/ doc)
 (vlax-for blk	(vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
     (vlax-for	obj blk
  (vl-catch-all-apply 'vla-put-color (list obj 0))
(vl-load-com)
Beautiful thank you! I wasn't sure on how to get ByBlock without using the word ByBlock. I appreciate your help!
