Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Full Member
    donaldo's Computer Details
    windows 7
    Surveying
    donaldo's Discipline Details
    Site Engineer, Construction
    Surveying
    Land Surveying, Engineering Surveying - setting out roads, buildings etc. Downloading and drafting surveys when surveying, using designers CAD drawings for extracting data for setting out construction works.
    AutoCAD 2012
    Mar 2011
    East Sussex, England
    30
    Default Adding Multiple Numbers to Drawing without typing them in
    Is there a quicker way of inserting multiple numbers to a drawing without inserting them manually? I have a drawing of a Large Carpark which I surveyed and I want to add the Carpark Bay numbers in. It won't take me that long to type them in manually but curious as to whether there is a quicker way. I thought maybe running a list of numbers in excel and then importing them or something like that?
    Thanks
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    It will depend on the layout, a list in excel will work, if you lay it out in combination with autocad command keywords and copy it into the Autocad command line as a sort of script (or make it a script) but this needs you to know all the location points of the numbers, or just an incremental list.
    Another method if your numbers are dotted about, would be create a macro that automatically increments a number and places that with just the click of your mouse. Both methods work well in LT but take some time to set up, so if this is one off work and there isn't that much, then it's not (financially) worth your time, if you do this regularly then it's worth looking at. But mentally it is well worth the effort if you enjoy solving puzzles, and the more often you do this the quicker you get. I would personally rather spend an hour creating a script or macro to save half an hours work than spend that half an hour doing monotonous repetative work. (just don't tell the boss). But mostly it is a considerable saving in time
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Full Member
    windows 7
    Surveying
    Surveying
    AutoCAD 2012
    Mar 2011
    30
    Its something I do frequently enough to warrant developing a speedier way of doing it but that's a whole new language to me so it may take some time. I'll mess with excel first. Thanks for tips
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Just to clarify...you are using AutoCAD LT 2012 is that correct?
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    OK here's a simple example it just uses the row numbers to drop incrementing numbers into a drawing. To use excel this way all you need do is highlight the cells colored yellow and press Ctrl+c (copy to clipboard).
    In Autocad click inside the command line, the cursor has to be active in the command line or it will paste as an ole object in the drawing, so click twice inside the command until the cursor is active then paste Ctrl+v from the clipboard, thats it.
    This example places 10 numbers in the drawing at x=0 and y= 10 up to 100
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Or, if you really are using LT and not full AutoCAD, you could utilize an auto increment numbering macro. There's one posted here...http://forums.augi.com/showthread.ph...for-AutoCAD-LT
    I have not tested it. I'll leave that to you if your interested.
  7. #7
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    if you were to use excel to make some sort of an array of numbers (say parking lot) how can you get the distance right?
  8. #8
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    dont remember if the cells and columns are buy units (inches/millimeters/etc).
  9. #9
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    709
    Here's a link for a couple of number incrementing macros that work with Autocad LT.
    I've used them myself many times.
    http://www.cadeverything.com/help/sh...-numbers-in-LT
    Both are originally from the Augi forum, and the authors are credited in that link.
    (The first one is the same as ReMark linked to above).
    *** Out of Beer Error ->-> Recovering Memory***
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,577
    Using Autocad easy if car park bays are straight pick 1st bay line, pick last bay line, enter start number if not nil, text is placed based on the number of lines crossed and half way between each line. I dont have code yet but big hint is ssget "F". I know it works based on something else I have done.
  1. Coding Help - Adding numbers to text
    By Piper in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th May 2018, 05:28 am
  2. adding a comma to numbers in autocad
    By newchurchr in forum AutoCAD Beginners' Area
    Last Post: 11th Feb 2016, 01:17 pm
  3. Adding numbers in a schedule
    By ic_whitehead in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Sep 2013, 10:43 pm
  4. Adding numbers together in text strings
    By BrianTFC in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2012, 03:58 am
  5. adding numbers to numbers
    By philk in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Feb 2006, 05:45 pm
