Results 1 to 3 of 3
    Forum Newbie
    Transport
    AutoCAD 2016
    Oct 2017
    1
    Default Adjusting the Smoothness of 3D Objects...
    I'm rather new to AutoCAD 3D, having come from an environment where I worked with IronCad extensively for years. I no longer have IronCad available to me, but I do have AutoCAD 2016. I'm doing pretty well with it, but I do have a question regarding a file I fed to a 3D printer yesterday. It has to do with the ability to adjust the smoothness of a curved object's surface. The object in question is, essentially, a ring of about 6" in diameter & 1" thick. Yesterday when I exprted it as an .stl file and sent it to the 3D printer for realization, it ended up with curved surfaces that were made up of a series of facets rater than a smooth, continuous surface. Is there a setting in AutoCAD (v.2016 in this case) that will allow me to adjust the smoothness of objects such as this?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,111
    FACETRES and VIEWRES maybe ISOLINES, these are system variables. You can also use OPTIONS>Display then adjust the numbers in Display Resolution section.
    What Operating system are you using?
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Set FACETRES to 10 and then export to .stl.
    You can also use the 3DPRINT command to export.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. Smoothness of a revolution
    By the downing effect in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Nov 2012, 06:50 pm
  2. rendering smoothness
    By kayaan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Jan 2011, 06:10 am
  3. smoothness
    By blowe56789 in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2008, 11:12 am
  4. Polyline arc smoothness.
    By Gregg Kuljian in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2006, 04:52 pm
  5. Getting smoothness at the joint
    By kanyakumari_t in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jan 2006, 03:09 pm
