Results 1 to 5 of 5
Thread: Array problem
    Junior Member
    not applicable
    Feb 2013
    12
    Default Array problem
    Hi All,
    trying to draw something using path array.
    I've attached part of the drawing. I want the objects to have a 2mm space between them.
    any how or info on how to do this would be hugely greatful
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I see a couple of problems. 1) The path is not continuous (i.e. - it is a series of separate lines and arcs). 2) The first, short, line segment does not connect to the first arc segment.
    Why do you want such a small space between the objects given the shape of your 3D solid (identified as a "car_top")?
    I would recommend that you first move the line segment into the proper position. Next I would use the PEDIT or JOIN command to make your lines and arcs (I think there is even a single lightweight polyline too) into one continuous polyline. Reposition the car top relative to the beginning of the line and invoke the ARRAY command.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Here's what I was able to accomplish. For the sake of clarity I made the path layer white and the car_top layer magenta. Having both objects the same dark color just doesn't work for me.
    Top down view in 2Dwireframe visual style.
    A portion of the array along the path.
    Closeup of array in a straight segment of the path.
    Closeup of array at beginning of path. See what is happening with the corners of the "car_top" as it makes the turn?
    Junior Member
    not applicable
    Feb 2013
    12
    Thanks for the input ReMark. I see what you mean by the corners.
    This is a segment of a piece of machinery I seen. It's a carousel, which is a loop around a warehouse.
    If I move the base point, would it prevent the corners overlapping?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I think the separation distance is too small. You specified 2mm.
  1. Problem with Path Array
    By basM in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Oct 2016, 06:45 pm
  2. Problem with Polar Array
    By gotchy in forum AutoCAD Beginners' Area
    Last Post: 20th Apr 2013, 05:33 pm
  3. ARRAY Problem
    By provas_ce in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2013, 06:03 pm
  4. Angle of array problem
    By Andre in forum AutoCAD Beginners' Area
    Last Post: 23rd Aug 2010, 02:45 am
  5. array problem
    By MMS in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Mar 2007, 02:40 am
