Hatch pattern to layername
halam
Hi, I am looking for a lisp that will put all used hatches in a dwg file layers according to their pattern name. Have you seen something than can do this? Would be most welcome to clean up my act.
  • Replies 21
  • halam
    10
  • Grrr
    6
  • ronjonp
    4
  • Tharwat
    1
Posted Images
Hi,
Its simple enough. ;)
Have you written any codes for this task?
Sorry for my lazyness. I thought I'd better ask for a good starting point..
heres a bit of practice (activex approach) :
(defun C:test ( / pref suf *error* SS acDoc Lyrs acSS pat )
 (setq ; Adjust to suit
   pref ""
   suf ""
 ); setq
 (defun *error* (m)
   (and acSS (vla-Delete acSS))
   (and m (princ m)) (princ)
 ); defun *error*
 (cond
   ( (setq SS (ssget "_X" '((0 . "HATCH")))) (setq Lyrs (vla-get-Layers (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))))
     (vlax-for o (setq acSS (vla-get-ActiveSelectionSet acDoc))
       (setq pat (strcat pref (vla-get-PatternName o) suf))
       (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-Item (list Lyrs pat))) (vla-Add Lyrs pat) )
       (vla-put-Layer o pat)
     ); vlax-for
 ); cond
 (*error* nil) (princ)
); defun C:test
(vl-load-com) (princ)
...untested.
This is quite easy to create. But what are the names of the layers? Do they have to match the hatch patterns name?
yes, with a prefix like XX_
Vanilla version:
(defun c:foo (/ s)
 (if (setq s (ssget "_x" '((0 . "hatch"))))
   (foreach h (mapcar 'cadr (ssnamex s))
     (entmod (append (entget h) (list (cons 8 (strcat "XX_" (cdr (assoc 2 (entget h))))))))
Pretty fantastic to clean up some DWG exports
How can i made to work all hatch layers now get color 253 and transparancy 50% by default.
..(vla-put-layercolor..
..(vla-put-layertransparancy..
(defun c:foo (/ l s)
 (regapp "AcCmTransparency")
     (entmod (append (entget h) (list (cons 8 (setq l (strcat "XX_" (cdr (assoc 2 (entget h))))))))
     (entmod (append (entget (tblobjname "layer" l))
	      '((62 . 253))
	      '((-3 ("AcCmTransparency" (1071 . 33554559))))
And modification on my code (again - not tested) :
(defun C:test ( / pref suf LM:SetLayerTransparency *error* SS oCol acDoc Lyrs acSS pat lyr )
   pref ""
   suf ""
 ); setq
 ; https://www.theswamp.org/index.php?topic=52473.msg574082#msg574082
 (defun LM:SetLayerTransparency ( lay trn / ent ) ; Lee Mac
   (defun LM:trans->dxf ( x ) (logior (fix (* 2.55 (- 100 x))) 33554432) )
   (cond
     ( (not  (<= 0 trn 90)) nil)
     ( (if (setq ent (tblobjname "layer" lay)) (progn (regapp "accmtransparency") (entmod (append (entget ent) (list (list -3 (list "accmtransparency" (cons 1071 (LM:trans->dxf trn))))))))) )
 ); defun LM:SetLayerTransparency
 (defun *error* (m)
   (and (eq 'VLA-OBJECT (type oCol)) (not (vlax-object-released-p oCol)) (vlax-release-object oCol))
   (and acDoc (vla-EndUndoMark acDoc))
 ); defun *error*
 (cond
     (and
       (setq oCol (vla-GetInterfaceObject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar 'acadver) 1 2))))
     ); and
     (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)
     (vla-put-ColorMethod oCol acColorMethodByACI)
     (vla-put-ColorIndex oCol 253)
       (if (vl-catch-all-error-p (setq lyr (vl-catch-all-apply 'vla-Item (list Lyrs pat)))) (setq lyr (vla-Add Lyrs pat)) )
       (vla-put-TrueColor lyr oCol)
       (LM:SetLayerTransparency (vla-get-Name lyr) 50)
     ); vlax-for
 ); cond
); defun C:test
Still couldn't figure out how to assign layer transparency with activex.
@Grrr, you don't have to use the color object (AutoCAD.AcCmColor.XX) when assigning index colors.
Try:
(vla-put-color (vlax-ename->vla-object (tblobjname "layer" "0")) 5)
@Ron, thanks - I've forgot that there was a Color property.. :ouch:
Once I started mixing up true and index colors, I got used to obtain the color object like that (TrueColor property). For this case I thought it would be faster to obtain and manipulate just once the interface color object, and just apply it to each layer (rather than obtaining TrueColor property for each layer).
This works just fine allready!
One further wish.. it would be most useful to have a part in which user can filter it based on the name to assign both color and transparency seperate.
In my case i want to be able to color all hatches translated from Revit Fill Patterns into purple, and the rest 253 or other. Also, if there is a way to filter AutoCAD custom hatches, this would be very welcome to.
I think this start with something like this beneith. Hope you get the picture. I don't know to use wildcards searches and to make this good into this fine piece of code is also beyond my skills.
   (setq pat_eval (vla-get-PatternName o))
(if (= pat_eval
      (_PF)                                      ; filter Pattern Fill, how to use wildcard in name ?
      (setq                                      ; Adjust to suit in the case _PF
          pref "x-Revit-PF-"
          suf  " to be fixed"
(if (= pat_eval
      (_Solid)                                   ; filter Regular AutoCAD hatch
          pref "x-AC-"
          suf  " is ok"
What you want is a conditional statement:
(setq patname (strcase patname))
(cond ((wcmatch patname "*_PF*")
      (setq pref "x-Revit-PF-"
     suf  " to be fixed"
     ((= patname "SOLID")
      (setq pref "x-AC-"
     suf  " is ok"
UPDATED
(defun C:getpatlayer (/           pref
                     *error*     SS
                     oCol        acDoc
                     Lyrs        acSS
                     pat         lyr
                     pref_eval
                     lcol
                    )                            ; https://www.theswamp.org/index.php?topic=52473.msg574082#msg574082
   (defun LM:SetLayerTransparency (lay trn / ent) ; Lee Mac
       (defun LM:trans->dxf (x) (logior (fix (* 2.55 (- 100 x))) 33554432))
       (cond
           ((not (<= 0 trn 90)) nil)
           ((if (setq ent (tblobjname "layer" lay))
                       (entmod
                           (append
                               (entget ent)
                               (list (list -3
   )                                             ; defun LM:SetLayerTransparency
   (defun *error* (m)
       (and m (princ m))
   )                                             ; defun *error*
   (cond ((and (setq SS (ssget "_X" '((0 . "HATCH"))))
          )                                      ; and
              (setq pat (vla-get-PatternName o))
              (if (cond ((wcmatch (vla-get-PatternName o) "FP_*")
                         (setq pref "x-hatch-pat-Revit-"
                               suf  ""
                               lcol 6
                        ((wcmatch (vla-get-PatternName o) "SOLID")
                         (setq pref "x-hatch-pat-"
                               suf  ""
                               lcol 253
                        ((wcmatch (vla-get-PatternName o) "DOTS")
                               suf  ""
                               lcol 253
                        ((wcmatch (vla-get-PatternName o) "ANGLE")
                               suf  ""
                               lcol 254
                        ((wcmatch (vla-get-PatternName o) "JIS_*")
                               suf  ""
                               lcol 4
                        ((wcmatch (vla-get-PatternName o) "ACAD_*")
                               suf  ""
                               lcol 3
                        ((wcmatch (vla-get-PatternName o) "ISO_*")
                               suf  ""
                               lcol 7
                        ((wcmatch (vla-get-PatternName o) "AR-*")
                               suf  ""
                               lcol 5
                    (vla-put-ColorIndex oCol lcol)
                         (setq pat (strcat pref pat suf))
                                                               (list Lyrs pat)
                  )                              ; progn
              )                                  ; if
          )                                      ; vlax-for
   ))                                             ; cond
   (*error* nil)
)                                                 ; defun C:test
(vl-load-com)
Edited by halam
UPDATED
Hans, try with:
 (if
   (cond
     ( (wcmatch (strcase pat) "*_PF*")
       (setq
         pref "x-Revit-PF-"
         suf  " to be fixed"
     ( (= (strcase pat) "SOLID")
       (setq
         pref "x-AC-"
         suf  " is ok"
   ); progn
 ); if
); vlax-for
It could be shortened a bit, but I don't have time to revise further.
Thanks. That works!!!! :)
Update the code above.
I have two statements in mind.
The first is ((wcmatch (strcase pat) "FP_*") to filter the Revit Fill patterns
The other one should be the opposite of that for other hatches not coming from Revit exports.
something like (=/ "FP_*")
