Russello Posted October 19, 2017 Share Posted October 19, 2017 Hi again legends. I need your help once again. I dont know how to replace/set block attribute values when I insert it via lisp if it has more than 1 line (vertically). If it is only one line (horizontally), I know how. for example I have 4 tags, so the code goes: (command "-Insert" "Sampleblock" "_non" Data_block aa "" LineValue1 LineValue2 BearingValue DistanceValue ) (assuming all values were set and achieved) But when I'm dealing with attributes more than 1 line (vertically), I dont know how. Sample Image Is there a way to write in a lisp that says set the value of POINT1 with this, POINT2 with this, and goes on. P.S. I already know (maybe hehehe) how to get the values that I want, I just dont know how to set them as values on the inserted block when it is more than 1 line vertically. Thanks again for your help. kudos Quote Link to comment Share on other sites More sharing options...
Russello Posted October 19, 2017 Author Share Posted October 19, 2017 forgot to attach the image. here it is Quote Link to comment Share on other sites More sharing options...
Grrr Posted October 19, 2017 Share Posted October 19, 2017 You should upload dwg of that block for testing. The following code works for my made on-the-fly test block: (defun C:test ( / fuzz e enx s srt1 srt2 ans p px L i ) (and (setq fuzz 1e-1) ; adjust (setq e (car (nentsel "\nPick attribute: "))) (setq enx (entget e)) (member '(0 . "ATTRIB") enx) (setq s (getstring t "\nText prefix: ")) (mapcar 'set '(srt1 srt2) (if (setq ans (progn (initget "Row Column") (= "Column" (cond ((getkword "\nSpecify [Row/Column] <Column>: "))("Column"))))) (list car cadar) (list cadr caar) ) ) (setq p (cdr (assoc 10 enx))) (progn (foreach x (vlax-invoke (vlax-ename->vla-object (cdr (assoc 330 enx))) 'GetAttributes) (and (equal (srt1 p) (srt1 (setq px (vlax-get x 'InsertionPoint))) fuzz) (setq L (cons (list px x) L)) ) ) (if L (setq L (vl-sort L '(lambda (a b) ((if ans > <) (srt2 a) (srt2 b)))))) ); progn (setq i 0) (foreach x (mapcar 'cadr L) (vlax-put x 'TextString (strcat s (itoa (setq i (1+ i))))) ) ); and (princ) ); defun C:test AttribBlockTable.dwg Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 19, 2017 Share Posted October 19, 2017 (edited) I've copied Grrr's code and I modified it slightly in case you want Vanilla ALISP... @Grrr, if you use (vla-xxx) functions, you should not forget to write also (vl-load-com)... (defun C:test ( / fuzz e enx s srt1 srt2 ans p blk att px L i ) (and (setq fuzz 1e-1) ; adjust (setq e (car (nentsel "\nPick attribute : "))) (setq enx (entget e)) (member '(0 . "ATTRIB") enx) (setq s (getstring t "\nText prefix : ")) (mapcar 'set '(srt1 srt2) (if (setq ans (progn (initget "Row Column") (= "Column" (cond ((getkword "\nSpecify [Row/Column] <Column>: "))("Column"))))) (list car cadar) (list cadr caar) ) ) (setq p (cdr (assoc 10 enx))) (progn (setq blk (cdr (assoc 330 enx))) (setq att (entnext blk)) (while att (and (= (cdr (assoc 0 (entget att))) "ATTRIB") (equal (srt1 p) (srt1 (setq px (cdr (assoc 10 (entget att))))) fuzz) (setq L (cons (list px att) L)) ) (setq att (entnext att)) ) (if L (setq L (vl-sort L '(lambda ( a b ) ((if ans > <) (srt2 a) (srt2 b)))))) ); progn (setq i 0) (foreach x (mapcar 'cadr L) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat s (itoa (setq i (1+ i))))) (assoc 1 (entget x)) (entget x)))))) ) ); and (princ) ); defun C:test Edited October 19, 2017 by marko_ribar Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 20, 2017 Share Posted October 20, 2017 Could not resist my $0.05 Would a Table work better as you can keep adding rows ? ; By Alan H ; 3 line dcl ; sample code (ah:getval3 "Row No" 5 4 "Column No" 5 4 "New value" 20 18) (defun AH:getval3 (title1 width1 limit1 title2 width2 limit2 title3 width3 limit3 / fo fname) (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) ;(setq fo (open (setq fname "c:\\ACADTEMP\\GETVAL.DCL") "w")) (write-line "ddgetval3 : dialog {" fo) (write-line " : column {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title1 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width1 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit1 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key2" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title2 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width2 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit2 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key3" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title3 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width3 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit3 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) ; code part (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval3" dcl_id)) (exit)) (mode_tile "key1" 3) (action_tile "key1" "(setq val1 $value)") (mode_tile "key2" 3) (action_tile "key2" "(setq val2 $value)") (mode_tile "key3" 3) (action_tile "key3" "(setq val3 $value)") (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 val2 and val3 as strings (vl-file-delete fname) ) ; defungetval3 Quote Link to comment Share on other sites More sharing options...
Russello Posted October 20, 2017 Author Share Posted October 20, 2017 Hi all. Thank you Master Grr, marko_ribar, and BIGAL. You have provided good solutions but it is not really what Im looking for, it's not your fault it was mine. The way I wrote my problem seems to general. Anyways, I found a solution (maybe) and I will give it a shot. please keep in touch Master because I know I will face a lot of problems. hehehe. I've seen these functions at the acadauto.chm (autodesk shared files) and I think this is what im looking for. (vlax-variant-value (vla-GetAttributes. . . (vla-put-TextString (vlax-safearray-get-element. . . . Hoping Im on the right path but with your guidance, nothing to worry. hehehe Regards, Russello Quote Link to comment Share on other sites More sharing options...
Grrr Posted October 20, 2017 Share Posted October 20, 2017 No problem Marko, Thanks for the reminder about (vl-load-com), I had a discussion with Roy before about loading it and ended up with (or vlax-get-acad-object (vl-load-com)). BTW if you wanted pure vanilla then the vl-sort function should be substituted with a custom one. Rusello, BIGAL posted somewhere a simple example how to assign a value to the nth attribute. Maybe that was here or in a more previous thread. But that approach relies on the attribute's creation order. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 20, 2017 Share Posted October 20, 2017 @Grrr, not all prefixed "vl-" functions are (vl-load-com) dependent... I have a list of those functions and among them is also (vl-sort)... So my version is Vanilla - you may call it that as it don't need (vl-load-com) invoked at all... Here is list of those functions FYI : VL-ACAD-DEFUN VL-ACAD-UNDEFUN VL-ARX-IMPORT VL-BB-REF VL-BB-SET VL-BT VL-BT-OFF VL-BT-ON VL-CATCH-ALL-APPLY VL-CATCH-ALL-ERROR-MESSAGE VL-CATCH-ALL-ERROR-P VL-CMDF VL-CONSP VL-DIRECTORY-FILES VL-DOC-EXPORT VL-DOC-IMPORT VL-DOC-REF VL-DOC-SET VL-EVERY VL-EXIT-WITH-ERROR VL-EXIT-WITH-VALUE VL-FILE-COPY VL-FILE-DELETE VL-FILE-DIRECTORY-P VL-FILE-RENAME VL-FILE-SIZE VL-FILE-SYSTIME VL-FILENAME-BASE VL-FILENAME-DIRECTORY VL-FILENAME-EXTENSION VL-FILENAME-MKTEMP VL-GET-RESOURCE VL-INFP VL-INIT VL-LIST->STRING VL-LIST-EXPORTED-FUNCTIONS VL-LIST-LENGTH VL-LIST-LOADED-VLX VL-LIST* VL-LOAD-ALL VL-LOAD-COM VL-LOAD-REACTORS VL-MEMBER-IF VL-MEMBER-IF-NOT VL-MKDIR VL-NANP VL-POSITION VL-PRIN1-TO-STRING VL-PRINC-TO-STRING VL-PROPAGATE VL-REGISTRY-DELETE VL-REGISTRY-DESCENDENTS VL-REGISTRY-READ VL-REGISTRY-WRITE VL-REMOVE VL-REMOVE-IF VL-REMOVE-IF-NOT VL-SOME VL-SORT VL-SORT-I VL-STRING->LIST VL-STRING-ELT VL-STRING-LEFT-TRIM VL-STRING-MISMATCH VL-STRING-POSITION VL-STRING-RIGHT-TRIM VL-STRING-SEARCH VL-STRING-SUBST VL-STRING-TRANSLATE VL-STRING-TRIM VL-SYMBOL-NAME VL-SYMBOL-VALUE VL-SYMBOLP VL-UNLOAD-VLX VL-VBALOAD VL-VBARUN VL-VLX-LOADED-P VLARTS-INIT VLAX-ADD-CMD VLAX-FOR VLAX-REMOVE-CMD VLISP-DCLRES-LIST VLISP-DCLRES-LOAD-DIALOG VLISP-EXPORT-SYMBOL VLISP-FASRES-LIST VLISP-FASRES-LOAD VLISP-IMPORT-EXSUBRS VLISP-IMPORT-SYMBOL VLISP-INIRES-LIST Regards, M.R. Quote Link to comment Share on other sites More sharing options...
Grrr Posted October 20, 2017 Share Posted October 20, 2017 Thanks Marko, I was unaware of this (maybe someone mentioned before this to me - but I have a bad memory). Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 21, 2017 Share Posted October 21, 2017 Grr you are correct (setq atts (vla-GetAttributes then a (put (nth x atts) whilst it will work with rows and columns you do need to know how many of each exist was the block created x x x x y y y y z z z or x y z x y z and so on. Working out correct attribute is easy, the code would have to be hard coded for say how many columns. Quote Link to comment Share on other sites More sharing options...
