Results 1 to 8 of 8
Thread: Snapping
    Junior Member
    Civil
    Civil 3D 2017
    Oct 2017
    17
    Default Snapping
    Hello there!
    I have a fairly simple question, but it has been bugging me for a while now.
    I know that there are many different snap settings. But for example if I take some type of snap, I drag a line near the place I want it to snap, it shows where it will snap, but if my mouse is a bit above the target ( green square for example ) , it will just draw it there instead of snapping to where it was supposed to.
    UPDATE: Also while im at it. Is it possible to have the dynamic input in isometric grid understand that the 0 degrees is 30 degrees on the sheet? Or I have to just calculate it on the fly.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Your aperture and pickbox may be sized a bit too large.
    Have you noticed that the cursor will sort of LOCK ON to the snap marker? Any further movement will break the lock. It happens pretty much right away as soon as you first come close enough to it. Also, don't click on the marker when is is dashed, only when it is solid lines.
    Try polar tracking with vector lines displayed. At least then when the vector lines are spinning crazily around the snap marker, you know you are not locked onto the snap. See the attached images. The first one is DSETTINGS (drafting settings). The second is OPtions > Drafting tab.
    Yes, I have a weird set of angles to track while polar tracking is active. I recommend 5 deg. at the smallest. I have to fix mine.
    I am not sure about how dyn input works in Iso. I don't use it much, but I think polar tracking may help you with 30 deg added to the tracking angle list.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    There are only two ways to ensure that the osnap either grabs onto an object or doesn't acquire a picked point. One is to not use running osnaps and instead use another method to set the osnap needed at the moment. The obvious one is to start the line command and then type END, but that is not efficient. I use F-Keys with each one assigned to an osnap, so I start the line command and hit F1 for endpoint and pick on the line. You can use keyboard overrides as well.
    The other way is to set OSNAPOVERRIDES to 1.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    Junior Member
    Civil
    Civil 3D 2017
    Oct 2017
    17
    Quote Originally Posted by Dana W View Post
    what exactly does polar tracking do ?
  6. #6
    Junior Member
    Civil
    Civil 3D 2017
    Oct 2017
    17
    Quote Originally Posted by rkent View Post
    What will the last command do ? I feel like it will be annoying to remember each snap for the each button
  7. #7
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    825
    10 AutoCAD temporary override keys
    Enables Snap Enforcement
    Override key: Hold SHIFT + S or SHIFT + ;
    This key will activate snap enforcement, changing OSNAPOVERRIDE system variable from 0 to 1.
    You can add more if you like.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by rihiz View Post
    Polar tracking adds the ability to acquire snaps at discernable angles while showing you what the angle is. Typing in some (let's call them prefered) angles to the polar tracking angle table will allow the cursor to snap onto a "vector" at these angles.
    For instance, you start a pline and pull it at an angle for a distance. Using the dynamic cursor readout, and watching your projected polar tracking vector line(if displayed) will help you find, say 45 deg. visually without having to type in your angle and distance. PT will snap mildly (the cursor only) to your vector as sort of a lock-on, then you can keep to that angle to pull to the end point of your pline,or key in a distance. There is a very mild assistance present to holding the cursor on a particular vector, but it is not nearly as strong as the lock to X and Y that ortho mode uses, probably less than 1%.
    While drawing a line perfectly horizontal, PT will display a vector line, which you can see make an obvious snap and unsnap, if you pull the cursor off the horizontal or bring it back on. This works with any of the angles defaulted or added to the angle table in the above image I posted.
    Displaying the polar tracking vector lines will show you which snap you have "acquired" by establishing a displayed vector line from your cursor to that snap.
    You can change your orientation to the acquired snap and vector in, then snap in on a new location, say perpendicular to the original acquired snap even if the perpendicular point is not on the object owning the originally acquired snap.
    As long as the PT vector line(s) are visible, you are NOT on the snap point.
    There's more, but I can't seem to describe it easily. To me Polar tracking with vector lines is like having a third hand.
    Polar tracking does not function at all well with Ortho mode turned on.
    Sorry, that is not a very clear explanation. I probably should just copy and paste some stuff out of the F1 Help if I can find it. I personally find AutoCad Help as informative as reading the Wall Street journal through a pebbled glass window.
  1. Line snapping is not snapping to correct area - need help
    By Joestradamus in forum Civil 3D & LDD
    Last Post: 26th Feb 2013, 05:23 pm
  2. Snapping
    By Fastdraft in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 23rd Feb 2012, 07:37 pm
  3. Snapping
    By Interior in forum AutoCAD Beginners' Area
    Last Post: 17th May 2009, 08:28 pm
  4. Snapping in 3d
    By rustysilo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2009, 01:46 am
  5. snapping in 3ds max
    By chrisdarmanin in forum 3D Modelling
    Last Post: 24th Dec 2008, 02:27 am
