I have a lisp routine from Tharwat. I customized something so I can use setq variables (through getstring). But the code does not work, nothing happens. The input can be numbers and letters. What am I doing wrong?
Does anyone have an idea?
(defun c:test (/ ss)
 ;; Tharwat 15.12.2015    ;;
[color=red](setq str1 (getstring T "\nIDnr: "))
(setq str2 (getstring T "\nROOMnr: "))[/color]
 (setq lst '([color=red]("TEXT1" str1)[/color]
               [color=red] ("TEXT2" str2)[/color] ;; -> add more list of (tag . value) as you want
 (princ "\nSelect the Attributed block(s):")
 (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1))))
   ((lambda (i / obj e f)
      (while (setq obj (ssname ss (setq i (1+ i))))
        (while
          (= "ATTRIB"
             (cdr (assoc 0 (setq e (entget (setq obj (entnext obj))))))
           (if
             (setq f (assoc (cdr (assoc 2 e)) lst))
              (entupd (cdr (assoc -1 (entmod (subst (cons 1 (cadr f)) (assoc 1 e) e)))))
     -1
Thanks in advance.
; error: bad DXF group: (1 . STR1)
Hi,
The getstring prompts are fine,
you need to check this tutorial to work out the list problem.
Hi,
Can you please try this untested modified codes and let me know?
(defun c:test (/ str1 str2 lst ss)
 ;; Tharwat 01.11.2017    ;;
(and (/= (setq str1 (getstring T "\nIDnr: ")) "")
     (/= (setq str2 (getstring T "\nROOMnr: ")) "")
     (setq lst (list (list "TEXT1" str1) (list "TEXT2" str2)))
     ((lambda (i / o e f)
        (while (setq o (ssname ss (setq i (1+ i))))
          (while (= "ATTRIB" (cdr (assoc 0 (setq e (entget (setq o (entnext o)))))))
            (if (setq f (assoc (cdr (assoc 2 e)) lst))
       -1
Yes yes..... working.
Thank you Tharwat and Grrr for your time. I am very pleased with the code
Good for you. :D
