Hii,
i have layer names like "Earth Line'", "Steel Line", "Concrete Line" etc..
so i need select all mentioned layer named containing objects and delete them.
any code for this task?
Thankyou..
Not tested:
(defun C:test ( / acDoc SS )
 (cond
   ( (not (ssget "X" '((8 . "Earth Line',Steel Line,Concrete Line")))) (prompt "\nNo Selection.") )
   ( (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
     (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)
     (vlax-map-collection (setq SS (vla-get-ActiveSelectionSet acDoc)) ''((x) (vl-catch-all-apply 'vla-Delete (list x))))
     (vla-Delete SS)
(vl-load-com)(princ)
grrr thank you very much. it is working.
can you provide selecting objects only? instead of delete.
Thank you.
Thank you.
Thanks for confirming,
This should limit the selection to the active viewport (as my previous suggestion selects objects in all viewports - and that might be unwanted) :
(defun C:test nil
 (sssetfirst nil
   (ssget "X"
     (list
       '(8 . "Earth Line',Steel Line,Concrete Line")
       (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))
:roll:
Give it a try..
My bad.. I thought you want to delete the layer itself..:geek:
LOL its ok and thank you..
