IF - condition (I need an additional LISP lesson)
Hi,
could anyone please help me out with this?
(if (= "UserName" (strcase (getvar 'loginname)))
I would like to add here some other UserNames
(if (= (or "UserName1" "UserName2" "...") (strcase (getvar 'loginname)))
but this didn't work.
How could I handle this?
kind regards
Bluebird1973
(cond ((wcmatch (strcase (getvar 'loginname)) "USERNAME,USERNAME1,USERNAME2,USERNAME3"))
     (code)
Be aware that = and wcmatch are case sensitive, so your example above will never work using strcase on the login name.
You could also use ( member ) but it is case sensitive as well
(if (member (strcase (getvar 'loginname))
          '("USERNAME" "USERNAME1" "USERNAME2" "USERNAME3"))
   (YadaYada))
-David
Or ...
(if (vl-position (strcase (getvar 'loginname)) '("USERNAME" "USERNAME1" "USERNAME2"))
Thank you guys !!!
GAP CLOSED! :D
... and of course ronjonp and David ... case sensitive ... USERNAME not UserName ...
kind regards
Bluebird1973
If you really wanted to use OR, per your original example:
(setq usr (strcase (getvar 'loginname)))
(if (or (= "USER1" usr)
       (= "USER2" usr)
       (= "USER3" usr)
But I would also likely use member/wcmatch in this scenario.
Had a bit of fun with the guys here so I used a cond as each user got a different response, the wcmatch would just give an answer of match found.
You could also accomplish that with ASSOC like so:
(print
 (cdr (assoc "USERNAME2"
      '(("USERNAME1" . "Message1") ("USERNAME2" . "Message2") ("USERNAME3" . "Message3"))
:lol: Or with a recursive or, which works the same as vl-some:
(defun _or ( f L ) (if L (if (not (f (car L))) (_or f (cdr L)) t)))
(_or '((x) (= "User2" x)) '("User1" "User2" "User3"))
BTW this is one is shorter, but I tried avoiding or:
(defun _or ( f L ) (if L (or (f (car L)) (_or f (cdr L)))))
How about:
(defun _or ( f l )
   (cond ((not l) nil) ((f (car l))) ((_or f (cdr l))))
How about:
(defun _or ( f l )
Looks 'cleaner', Lee! :)
Another recursive. :)
(defun user-p (u l)
 (cond ((= u (car l))) (l (user-p u (cdr l))))
