GregGleason Posted November 15, 2017 Posted November 15, 2017 I imagine this code needs just a quick fix. I am reading a CSV, split the record to a variable so I can test variables. I am getting an error when I try to invoke: (LM:str->lst fil ",") (defun c:ReadMyCSV () ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) (setq fl (open "C:\\Users\\ggleason\\Documents\\CAD\\AutoCAD\\Lisp\\Book1.csv" "r") ) (while (setq fil (read-line fl)) (if (not (null fil)) (princ (strcat fil "\n")) ; ***************************************** ; * Problem (LM:str->lst fil ",") ; ***************************************** (setq plt1 (append plt1 (list fil))) ) ;end if ) ;end while (close fl) ) Any suggestions on how I should fix it? Greg Quote
ronjonp Posted November 16, 2017 Posted November 16, 2017 Try something like this: 'out' will be your list of lists (defun c:readmycsv (/ fl out) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun lm:str->lst (str del / pos) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (lm:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) (if (setq fl (open "C:\\Users\\ggleason\\Documents\\CAD\\AutoCAD\\Lisp\\Book1.csv" "r")) (progn (while (setq fil (read-line fl)) (setq out (cons (lm:str->lst fil ",") out))) (close fl)) ) (reverse out) ) Quote
GregGleason Posted November 27, 2017 Author Posted November 27, 2017 ronjonp, That works great! The next question is how do I find when a given string matches the first record? The first record contains the .dwg name. I want to focus on the record that matches the file name of the open .dwg file. Greg Quote
ronjonp Posted November 27, 2017 Posted November 27, 2017 Maybe something like this: (vl-remove-if-not '(lambda (x) (wcmatch (strcase (car x)) (strcase (getvar 'dwgname)))) out) Quote
GregGleason Posted November 27, 2017 Author Posted November 27, 2017 Does that replace a line of code or is that added somewhere? Quote
ronjonp Posted November 27, 2017 Posted November 27, 2017 Replace the last line (reverse out) with the code above .. should give you only the lines that match the current drawing. Quote
GregGleason Posted November 27, 2017 Author Posted November 27, 2017 That works great! The last thing I am trying to do is isolate on a field, in this case "DATE", and return that value (see sample .csv file). Do I add another line of code underneath the replacement line of code you provided to do that? Book1.csv Quote
ronjonp Posted November 27, 2017 Posted November 27, 2017 Use this instead ( assumes that there is only one record ) will return the last item of the first sublist. (last (car (vl-remove-if-not '(lambda (x) (wcmatch (strcase (car x)) (strcase (getvar 'dwgname)))) out)) ) Quote
GregGleason Posted November 27, 2017 Author Posted November 27, 2017 That is close to what I was going for, but it picked up "NONE" as the value and not the date value. Also, there could be a situation where the column changes. Quote
ronjonp Posted November 27, 2017 Posted November 27, 2017 (edited) If the columns change you'll need to find the index on your header and use that to get the date. Edited November 28, 2017 by ronjonp Quote
GregGleason Posted November 28, 2017 Author Posted November 28, 2017 ronjonp, Let me say I appreciate all of the help on getting me on the right track. I revised the code so that it is a little more clear for me: (defun c:readmycsv (/ fl out) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun lm:str->lst (str del / pos) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (lm:str->lst (substr str (+ pos 1 (strlen del))) del)) ) ); End of lm:str->lst (if (setq fl (open "C:\\Users\\ggleason\\Documents\\CAD\\AutoCAD\\Lisp\\Book1.csv" "r")) (progn (setq mycount 0) (while (setq fil (read-line fl) ) (setq mycount (1+ mycount)) ; SYNTAX: (princ "\nMy Name is \nJohn")(princ) (princ mycount)(princ "\n") (setq out (cons (lm:str->lst fil ",") out) ) ; SYNTAX: (if (= 1 3) "YES!!" "no.") (if (= 1 mycount) (setq firstrec out)) ) ; End of "While" loop (close fl) (princ (strcat (itoa mycount) " records read\n")) ) ); End of "If" statement (princ firstrec)(princ "\n") (nth 3 (car (vl-remove-if-not '(lambda (x) (wcmatch (strcase (car x)) (strcase (getvar 'dwgname)))) out)) ) ) ; End of c:readmycsv The following is data in the list window: Command: READMYCSV 1 2 3 4 5 5 records read ((FileName VEC# PLANT DRAWINGTITLE1 DRAWINGTITLE2 DRAWINGTITLE3 DRAWINGTITLE4 SCALE)) "OLEFINS RV MITIGATIONS - BATCH B" What I discovered is that the last column is omitted from the data. The first record of the .csv is as follows: FileName,VEC#,PLANT,DRAWINGTITLE1,DRAWINGTITLE2,DRAWINGTITLE3,DRAWINGTITLE4,SCALE,DATE So the "DATE" column is being omitted by the code and it has "SCALE" as the last column. What do you suggest to change the code so that the last column of values are included? Quote
Roy_043 Posted November 28, 2017 Posted November 28, 2017 (edited) Try: (defun lm:str->lst (str del / pos) ; Modified version of Lee's code. (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (lm:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) Edited November 28, 2017 by Roy_043 Quote
ronjonp Posted November 28, 2017 Posted November 28, 2017 As Roy pointed out .. the code you have has been modified from Lee's original .. not sure where you got it from? Here's some commented changes to account for the 'DATE' column index changing. (defun c:readmycsv (/ fil firstrec fl i mycount out rec) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] String to process ;; del - [str] Delimiter by which to separate the string ;; Returns: [lst] List of strings (defun lm:str->lst (str del / pos) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (lm:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ; End of lm:str->lst (if (setq fl (open "C:\\Users\\ggleason\\Documents\\CAD\\AutoCAD\\Lisp\\Book1.csv" "r")) (progn (setq mycount 0) (while (setq fil (read-line fl)) (setq mycount (1+ mycount)) ; SYNTAX: (princ "\nMy Name is \nJohn")(princ) (princ mycount) (princ "\n") (setq out (cons (lm:str->lst fil ",") out)) ; SYNTAX: (if (= 1 3) "YES!!" "no.") (if (= 1 mycount) (setq firstrec out) ) ) ; End of "While" loop (close fl) (princ (strcat (itoa mycount) " records read\n")) ) ) ; End of "If" statement (princ firstrec) (princ "\n") ;; RJP - 11.28.2017 ;; Reverse results to put them in correct order (setq out (reverse out)) ;; Try to find index for 'DATE' column (if (and (setq i (vl-some '(lambda (x) (cond ((setq i (vl-position "DATE" (mapcar 'strcase x))) i))) out) ) ;; Check if we have a record that matches the current drawing name, changed to vl-some for speed (setq rec (vl-some '(lambda (x) (cond ((wcmatch (strcase (car x)) (strcase (getvar 'dwgname))) x))) out ) ) ) ;; Return date (nth i rec) ) ) ; End of c:readmycsv Quote
GregGleason Posted November 28, 2017 Author Posted November 28, 2017 Nailed. It. Thank you ronjonp! Greg Quote
ronjonp Posted November 28, 2017 Posted November 28, 2017 Nailed. It. Thank you ronjonp! Greg Glad to help Quote
