Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2007
    Oct 2017
    5
    Question [How to] Import .xls text with X and Y coordinate into AutoCAD
    Hi there, im using AutoCAD 2017 and I have a problem.
    I used DATAEXTRACTION command to create an excel file X and Y coordinate of mtext.
    When finished edit .xls file, I want to import it into AutoCAD again but i dont know how?
    Pls help me
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    It's real easy you use the concatenation commnand in excel
    =concatenation ("text" ,b1,",",c1," 90 2.5")
    Where b1 is x and c1 is y
    Just copy the column to the autocadcommand line
    Sorry typed on IPad may need a check.
    Just look at command line for manual entry
  1. Extract Text data at a XYZ coordinate from Autocad
    By kArThIcK hAcKeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2016, 12:35 pm
  2. Trouble with xyz coordinate import LISP
    By philnesterovic in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Apr 2016, 08:47 am
  3. Need the code for import the coordinate of text to file
    By Nad SK in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Dec 2010, 08:05 pm
  4. import text and data from excel into autocad
    By asdwer in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2010, 08:45 am
  5. import expot text from and to autocad
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Apr 2007, 09:39 pm
